Ballast Finally Filled My Ballast Box
   / Finally Filled My Ballast Box #1
Runner
Elite Member
Missouri
2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
I finally got around to filling my JD ballast box. Nothing unusual here, but thought I'd post it just as an example of the weight you can get in one. First, I had two, 82 lb bags of pre mixed concrete that had been sitting in my shop for several years and hardened up on me. So, I picked up two 90 lb bags of portland cement to augment the pre-mix.
First, I lined the inside of the box with two layers of 4 mil plastic sheet so as to prevent leakage and to facilitate removal of the concrete at a future date if so desired. Then, I mixed up one bag of portland and placed half of it in the box. After that, I took a sledge hammer and broke up the bag of pre mixed concrete and added that, then, more portland.
I then placed another layer of plastic as a bond breaker and then repeated the sequence of portland and hardened pre mix concrete. This left me with about 6 inches of extra space at the top of the box which I lined with an old floor mat from a car and then added 7, 42 lb quick tach weights from JD.
I originally bought the quick tach weights for the front of the tractor, but I think the ballast box is a good place to store them when I don't need them for front weight.
Anyway, here is the weight breakdown of the box:
Empty Box 129 lbs
Pre mix concrete (2) bags @ 82 lbs each
Portland cement (2) bags @ 90 lbs each
Quick Tach weights (7) @ 42 lbs each
Total Weight 767 lbs
Also, I just purchased one more 42 lb weight which fits perfectly with the other seven and makes a total of 809 lbs.
I figure this should be all the ballast I will ever need.
   / Finally Filled My Ballast Box #2
I think with your ballast box and rear wheel weights, you are good to go and then some.
   / Finally Filled My Ballast Box #3
It looks like the top edges of your ballast box are rolled forward - leaving a wide "slot" for the weights. Is this something you added or have ballast boxes changed? You lined it with plastic to allow for removal - how would you get the cement out in the future?
Looks like the cleanest prep I've seen on this board yet. Nice work.
   / Finally Filled My Ballast Box #4
That's a beautiful job, Runner, and since I'm an outcast from the Orange forum, I wonder if you'd be so kind as to tell me what the JD weight boxes go for?
I too have a Quick Hitch, and the Kubota box is a no-go.. I'd like to get the JD, drop it off at a buddy's body shop and have it sprayed orange...
Yours turned out great!
   / Finally Filled My Ballast Box #5
I think that is against the law in all 50 states and most of Cananda!! :D
   / Finally Filled My Ballast Box #6
Class work runner. My 790 has the same 6 wheel weights and 800+ lbs. ballast box but it is not weighted that fancy. Makes it solid as a rock while using the loader.
BlacknTan the JD website lists $206 for the ballast box.
For someone to have to paint it orange to match, that's just priceless.:D:D:D
All joking aside, they are really nice boxes.
   / Finally Filled My Ballast Box #8
SHHHHHHHHHHHHHHHHH !!!! Don't rat me out, but I have an orange green box myself. ;)
   / Finally Filled My Ballast Box #9
See, you'll come around. Next it's going to be a green tractor painted (yeck) orange.
BX,
Since I have the plastic between the box and the concrete and also between layers of the concrete, it "should" act as a bond-breaker and allow me to break it up with a few smacks of a sledge hammer and chisel.
My thought was that someday in the future I might come across some used elevator weights or something like that really cheap that would be easy to add/remove to taylor the weight to exactly what I need.
Now that I have it set up this way though, I'll probably never want to do anything different, but at least I can if I want to. If it was a solid chunk of concrete, there would be no chance of getting it out.
I almost hate to say this, but green and yellow have never been my favorite tractor colors. I kind of wish they made John Deere's in blue or orange....
   / Finally Filled My Ballast Box #13
I have seen at the factory in Dubuque they make rental equipment in Sunbelt's colors and all the military stuff is olive drab or tan so with enough $ or large enough order Deere will do whatever you want. ;)
   / Finally Filled My Ballast Box #14
i could see BLUE, but not Orange:rolleyes:
   / Finally Filled My Ballast Box #15
Not only paint.. I'll order the KUBOTA decal also... If I post pics with JD green on a Kubota, I might get banned from the Kubota forum! LOL
Just kidding, Just kidding! I like all the tractor colors.. And thanks for the info on price dirt ditch.. Couldn't build it for that price..
   / Finally Filled My Ballast Box #16
I'm 35. If you asked any kid in my generation to paint a tractor, I think it would be red.
Lucky for me, I've got my Dad's 1948 Farmall Cub next to the barn, waiting for me to restore it. It's sort of brown, with age. Call it "distressed red." I say, "lucky," because I can have my green Deere and a red tractor. Yipee!
   / Finally Filled My Ballast Box #17
BX,
Quoting Mythbuster Jamey Heiniman, "When in doubt, C4."
   / Finally Filled My Ballast Box #18
How do you start a myth? cause that would be so cool to see!:cool:
   / Finally Filled My Ballast Box #19
Nice work!! I like the way you incorporated the suitcase weights into the box, great place to store them and get use out of them. You should have plenty of ballast now, with the weight box and the wheel weights.
   / Finally Filled My Ballast Box #20
Urban legends and the Internet are good starting points.
If you get a chance, be sure to catch an old episode where they blew up an 8 or 10 yard transit mixer with 850 pounds of high explosives.
It doesn't get much better than that.
UNUSED FUTURE MB27-27" HYD MIXING BUCKET (A60432)
UNUSED FUTURE...
30in. Forks and Frame Skid Steer Attachment (A59228)
30in. Forks and...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
UNUSED FUTURE P45-56" MINI HYD BREAKER HAMMER (A60432)
UNUSED FUTURE...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
