Ballast Finally Filled My Ballast Box
   / Finally Filled My Ballast Box #1
Runner
Elite Member
Missouri
2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
I finally got around to filling my JD ballast box. Nothing unusual here, but thought I'd post it just as an example of the weight you can get in one. First, I had two, 82 lb bags of pre mixed concrete that had been sitting in my shop for several years and hardened up on me. So, I picked up two 90 lb bags of portland cement to augment the pre-mix.
First, I lined the inside of the box with two layers of 4 mil plastic sheet so as to prevent leakage and to facilitate removal of the concrete at a future date if so desired. Then, I mixed up one bag of portland and placed half of it in the box. After that, I took a sledge hammer and broke up the bag of pre mixed concrete and added that, then, more portland.
I then placed another layer of plastic as a bond breaker and then repeated the sequence of portland and hardened pre mix concrete. This left me with about 6 inches of extra space at the top of the box which I lined with an old floor mat from a car and then added 7, 42 lb quick tach weights from JD.
I originally bought the quick tach weights for the front of the tractor, but I think the ballast box is a good place to store them when I don't need them for front weight.
Anyway, here is the weight breakdown of the box:
Empty Box 129 lbs
Pre mix concrete (2) bags @ 82 lbs each
Portland cement (2) bags @ 90 lbs each
Quick Tach weights (7) @ 42 lbs each
Total Weight 767 lbs
Also, I just purchased one more 42 lb weight which fits perfectly with the other seven and makes a total of 809 lbs.
I figure this should be all the ballast I will ever need.
   / Finally Filled My Ballast Box #2
I think with your ballast box and rear wheel weights, you are good to go and then some.
   / Finally Filled My Ballast Box #3
It looks like the top edges of your ballast box are rolled forward - leaving a wide "slot" for the weights. Is this something you added or have ballast boxes changed? You lined it with plastic to allow for removal - how would you get the cement out in the future?
Looks like the cleanest prep I've seen on this board yet. Nice work.
   / Finally Filled My Ballast Box #4
That's a beautiful job, Runner, and since I'm an outcast from the Orange forum, I wonder if you'd be so kind as to tell me what the JD weight boxes go for?
I too have a Quick Hitch, and the Kubota box is a no-go.. I'd like to get the JD, drop it off at a buddy's body shop and have it sprayed orange...
Yours turned out great!
   / Finally Filled My Ballast Box #5
I think that is against the law in all 50 states and most of Cananda!! :D
   / Finally Filled My Ballast Box #6
Class work runner. My 790 has the same 6 wheel weights and 800+ lbs. ballast box but it is not weighted that fancy. Makes it solid as a rock while using the loader.
BlacknTan the JD website lists $206 for the ballast box.
For someone to have to paint it orange to match, that's just priceless.:D:D:D
All joking aside, they are really nice boxes.
   / Finally Filled My Ballast Box #8
SHHHHHHHHHHHHHHHHH !!!! Don't rat me out, but I have an orange green box myself. ;)
   / Finally Filled My Ballast Box #9
See, you'll come around. Next it's going to be a green tractor painted (yeck) orange.
BX,
Since I have the plastic between the box and the concrete and also between layers of the concrete, it "should" act as a bond-breaker and allow me to break it up with a few smacks of a sledge hammer and chisel.
My thought was that someday in the future I might come across some used elevator weights or something like that really cheap that would be easy to add/remove to taylor the weight to exactly what I need.
Now that I have it set up this way though, I'll probably never want to do anything different, but at least I can if I want to. If it was a solid chunk of concrete, there would be no chance of getting it out.
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
BUNDLE OF 2" X 2" X 22" ANGLE IRON (A54756)
BUNDLE OF 2" X 2"...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
23091 (A55758)
23091 (A55758)
2021 JOHN DEERE 325G SKID STEER (A52705)
2021 JOHN DEERE...
