Finally Building my Backhoe
/ Finally Building my Backhoe #81
Here is another option for your attachments. I use a pdf printer called "CutePdf"; it installs a a printer and you select it instead of your paper printer. This will allow you to create a pdf file of ANY document that you print. This would be a much better solution for viewers and it also makes the file size very small.
I posted several drawings here that were from AutoCad; the Pdf files are very nice because the drawing is maintained in a vector format, the lines and text are still crisp when zooming.
CutePdf is free; easy to find using Google.
BTDT.
I posted 2D shots of the drawings already. They are nice and all, but they don't come near what can be communicated in a full scale 3D sketchup file.
/ Finally Building my Backhoe #85
Any progress on the backhoe?...or are the house and wife keeping you busy?
Still plugging along on the remodel. Auction season has started too. I can't help myself. I have to go to auctions. If I didn't make so much money off of auctions, I may be able to talk myself out of it. Even if I had time right now, I don't have the space. I need to clear out some old tillers and electrical panels from the last auction.
/ Finally Building my Backhoe #87
Old tillers?
Old tillers?
Pathological auction impulses.
I paid $50 for two tillers. Neither works. I may have to count the tillers in the "You lose some" category. All is well, though. I've already doubled my money on this most recent auction (even including the tillers) via a few ebay sales.
/ Finally Building my Backhoe #91
You caught my eye as I'm looking for a PTO tiller. I need a project that I can justify to the wife. She wants to turn the entire backyard into garden.:confused2:
I've got a 40+ year old 8HP walk behind tiller. That's too much like work.:D Time to get a PTO unit and bring the tractor home.:thumbsup:
These are walk behinds. Used PTO tillers are scarce.
One year later, I finally got a minute to do a little more work on this backhoe.
I'm working on the bucket. See pictures below. The curved piece is 1/3 of a 16" pipe. It's 8" wide. Hopefully you can see in the second picture how the bucket is going to come together. I'm going to have to cut the sides of the bucket out with a torch. I'm even worse with a torch than I am with a welder.
/ Finally Building my Backhoe #96
Hi Iplayfarmer: That looks to be one honkin' heavy bucket when you have it done!! It looks like it should empty easily. Some designs I've seen look like they might be stingy about letting a load of clay go. That is what I will be digging in when I get mine built. I'm watching your build as well as another one on this forum and expect to glean lots of good information, tips and cautions to guide me along. If you are going to use the cutting torch a lot, have you considered using propane for fuel? It requires a special tip but the savings can be significant.
Yeah, the bucket will be heavy duty. 1/4" is what they had in that diameter pipe when I was at the steel yard. We'll see how it works. It may or may not dig well. It likely will not break, though.
Be patient as you watch this build. I'm split a hundred directions between all my hobbies and such, so this backhoe will only get a few hours every now and then. The major benefit to watching this thread is to get all the advice from the real experts when I propose some crazy amateur idea that will never work.
I have cut with both propane and acetylene. I suck equally with both, so I don't know what I'll do. I have a few pounds of acetylene left in the tank that I'll probably use and then switch back to propane. I haven't checked local acetylene prices, but rumor has it there's a shortage.
Here is the bucket all done for now. I'll also post a closeup of some of my welds. Feel free to criticize the welding as much as you want. I'm self taught and out of practice. Now that I'm done for the night, I'm wondering if I should have turned my heat up. The welding was done with a Lincoln AC/DC stick welder with 6011 rod.
This will probably be all I get done for another little while. It sure has been fun to be back into this project, though.
/ Finally Building my Backhoe #99
If'n the weld holds - its a good one, I always say! Don't go dissing your welds till you see some of mine. Also self taught and out of practice but game to keep on doing it anyway. I hope to get started on mine later this month.
Are you building from any set of plans or are you planning your own? What size tractor are you going to mount it to?
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2000 Ford E-350 Shuttle Bus (A64194)
2000 Ford E-350...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A64194)
1995 Khronert 307...
PARKER GRAVITY WAGON (A64278)
PARKER GRAVITY...
