Finally bought a small generator.
/ Finally bought a small generator. #51
So does that equate to one day at 100% load? Just curious. I am considering a whole house propane unit, but fuel use and the ability to have my propane tank refilled in an emergency are my huge concerns. I am talking a severe storm with power out for several days. Not just a infrequent outage.
If you haven’t installed the propane tank, yet, get a big Honkin 1000 gallon tank. We have a 500 gallon tank, and we have never come close to running out while using our 17 kW Kohler standby generator. But the longest power outage has been about five days. Interestingly, the gas supply company said that they would be willing to take out our 500 gallon and put in a 1000 gallon tank. My friend who has a fairly steep driveway, did that, and so his propane furnace lasts all winter long without a refill. I’ll have to ask him what his current consumption rate is like on his generator. It is a 22 kW Generac.
Meanwhile, when we built our place in 2002, we had the electrician install an external year plug and a 60 amps generator subpanel connected to it, with the proper lockouts. We then bought a King portable generator that was 6500/5500 W, and it powered what did we needed just fine. Now that we have the 17 kW whole house generator, we consider the portable one as a back up in case, for some reason, the main generator fails.
Interestingly, they did a lot of upgrades to the power pole system here, but we have been getting more power outages than before. It seems that every time there’s any kind of storm, including a rain storm, the power goes out. Fortunately, Hydro One, our power utility, is very well equipped with trucks and personnel, and they fix it up right quick.
/ Finally bought a small generator. #52
Our Generac standby is diesel powered but we still have 3, 500 gallon propane tanks we own outright so no rent involved plus we can fill with any supplier we want to, based on price per gallon. I usually keep 3 valved off (full at 85%) and run on one.
/ Finally bought a small generator. #53
Don't know about your gas company, but many around here reserve the option to charge tank rental if you don't use a certain amount of fuel in a year (usually equivalent to the size of the tank). Something to keep in mind if you don't experience a lot of long outages.
Bought the same one about 5 months ago, they had a coupon thing going so I paid $720 , have only put 1-2 hours on it so far. Changed the oil after about 1/2 hour of use. Seems to start very easy when it’s warm outside but not very easy when it’s cold outside. Kinda surprising how heavy the little thing is, if it wasn’t so heavy I’d probably store it inside the house during cold weather to insure it would start Easy when I needed it.
I picked up a similar-size Champion 10, maybe 12 years ago. So far only times I've run it have been semi-annual exercise runs, haven't had a power outage longer than a couple hours since I got it. Got a couple halogen work lights I plug into it for a load. Always starts easily, but I haven't tried it in the cold.
Got it mostly to power the refrigerator and freezer during a summer outage. Nothing I'd really need in the winter.
/ Finally bought a small generator. #55
A 250 gal tank is absolute minimum generac recommends. Most of my customers have 500-1000 gal tanks. mine is a 1000 gal buried tank.
a generator never runs at 100% if sized collectly. Mine runs less than 50% for extended outages. Highest in winter with heated water troughs and heat tape, lower in summer. I have a 22 kw and had a summer outage that lasted about 4 hours. Had 5 ton ac running entire time, lights, refer, freezers, etc and i had a Flo-Pro meter installed to watch actual gas usage. I averaged 1.25 gal per hour. I was amazed that the isoft starter i installed on my ac unit allowed my unit to run at an average of 25% according to my real time genmon monitor unit. The ac used to lug down my generator, but not anymore. It took about 60% off of the starting amp draw.
/ Finally bought a small generator. #56
I have a 3K Honda generator. Use it out & about on the property. Allows me to use my heavier corded power tools. In the 40+ years out here - never even once had to use the generator because of a power outage.
Excellent maintenance will provide superior service. Our Co-Op electric utility is the best.
Amazing out in the sparsely populated area compared to the California cities with rolling blackouts and powers safety shutoffs where my 1980’s Honda 5000 continues to keep the lights on.
/ Finally bought a small generator. #57
Smart keeping the little guy for just in case. My folks had a 20 kw on their house for my mom's medical equipment. Power went out and generac wouldn't start. Made a midnight run to our property to grab the 4500. Bad battery. Tech made it out the next day. Under warranty, I wasn't gonna touch it
If someone chooses a portable, don't just run the engine. Put that thing under a load routinely. I run mine monthly. Throw the switch and I crank either the heat or AC, everything on and even run the air compressor. For atleast an hour every month
/ Finally bought a small generator. #58
Can't make gas, diesel or propane, then solar could be a solution. A large solar gen is basically just a battery. You can recharge it with solar or gas gen. I am using ecoflow equipment (need more solar panels). Their Delta solar gens can start/stop their gas gen to recharge the battery.
Recently survived 4 days without power and only burned 2 gal of gas per day.
/ Finally bought a small generator. #59
I agree, solar is great when the sun shines, but it isn't a panacea, at least for us. We have a solar system with batteries, and this time of year we generate several times our daily load. The battery backup system is great. At most, we hear a small "thunk" as the transfer switch relay drops the grid, and that is the only symptom that we are on backup. Switching back to grid is silent. I have never noticed.
However, we still need sun for power to charge the batteries. Come November through February, we don't generate enough solar power to cover our usage (and we have propane for heat). Last winter, after a solid week of overcast weather, our batteries were only about half full. Then we were hit with a multi day snowstorm that was followed by an outage that had has pinching watts, trying to keep the lights and heat on. We were only recharging a 1-2kWh/day. If we move to heat pumps, our minimum load will go way up. (We get down to 0.2kW pretty easily, with bursts to 1.2kW to run the heat; while a heat pump would run us closer to a 2-3kW sustained usage.)
We still need a generator backup for extended winter storms and for outages due to wildfires, as we know first hand that large fires generate enough smoke to really tank solar production.
I think of it as belt and suspenders.
YMMV
All the best,
Peter
/ Finally bought a small generator. #60
A friend gave me one of those little Honda 2000 generators too, runs great but I think the stator is bad, I haven't looked at it for a few months ago but apparently it's a thing and about $200 unless anyone has any good deals they know of on the parts... it starts right up but the error light comes on or whatever and there's no voltage output...
I have no idea how to flash the coils on an inverter generator. On my old conventional generators, all you have to do is plug in an offset grinder or drill motor and give it a spin while the engine is running. I doubt very much that would work with an inverter in the way.
1667 (A57192)
1667 (A57192)
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
Rooster Weathervane (A55853)
Rooster...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
