Ballast Filling Tires
   / Filling Tires #1
JAE 3400
Ashtabula Ohio
Kubota L 3400
Well I had been sitting on the fence about getting my tires filled. After searching the forum on the subject and reading many posts I decided to do it. I found a tire dealer in N.W. Pa. They had Rim Guard for $2.50 a gal so I hauled it over there. They put 25 gal. in each wheel total cost $132.00 giving me about 535 lbs. of ballast. So after some mowing,FEL work and pulling out some small trees about three hours worth I must say it made a world of difference. The tractor seems much more stable and planted to the ground. If anybody else is on the fence I can highly recommend getting it done.
   / Filling Tires #2
Best thing I ever did to my L3400 also. The difference in the ride is quite noticeable. I just bought the kit from Napa and filled with water. My tractor lives indoors and our NW Winters are not that bad.
I would also recommend filling tires to any fence sitters. Brian
   / Filling Tires #3
I agree, had my L3400 tires filled from the dealer when I purchased it. The only way to go with the FEL. For me a no brainer! Joe
   / Filling Tires #4
The rear tires on my 4740 are filled, but the manual states that the front tires should not be filled. Anyone know why? The dealer said he would have no problem doing it - he even offered to use solid foam.
Even with max air pressure, the front tires are more than half flat when I have a full pallet of feed on the forks - so as I've been told in here, I run the risk of tire and rim separation. Consequently, I don't operate with a full pallet, but that's a p.i.a.
   / Filling Tires #5
If you fill the front tires they will not properly dampen the shock imposed on the front axle from the weight of the FEL. I have read that it is OK to fill with foam but i dont know for sure.
   / Filling Tires #6
The rear tires on my 4740 are filled, but the manual states that the front tires should not be filled. Anyone know why? .
Axial strain
A filled loader bucket is more than enough load on the front end.
   / Filling Tires #7
Makes sense. Thanks, guys.
23105 (A56859)
23105 (A56859)
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2000 INTERNATIONAL 4900 CAR HAULER (A57880)
2000 INTERNATIONAL...
2012 International Derrick Digger (A55973)
2012 International...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
Club Car Utility Cart (A55851)
Club Car Utility...
