field fence question
   / field fence question #21
(1) I'm no expert, but at your stretching H's, can you fence below the horizontal part of the H and leave a gap above it? I believe the hogs are not likely to jump over the horizontal bar, but the fawns probably would.
(2) Another idea might be to leave a vertical gap too narrow for hogs but allow the fawns to squeeze through.
(1) Sounds like a decent idea to try.
(2) Never going to happen. If a hog can get his nose between it, he will work his way through. I've seen wild hogs go through hog panel with heads that appeared bigger than the hole they went through.
I would run 2 strands of barbed wire on the outside of your field fence. Bottom strand on the ground tight, 2nd strand 6"-10" above that. 3" barbed wire, barbs 3" apart, would be best. Cost wise, try to re-use what you already have.
2013 Freightliner M2 Box Truck (A59814)
2013 Freightliner...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
