Ferguson tach
/ Ferguson tach #1
cannuck
M-F 1440
My "Co-Grandfather" ordered what he thought was a speedo for his M-F compact tractor, only to find a Ferguson tachometer in the box. He gave it to me thinking it might be a good spare for my M-F 1440 - but of course of no value to an Iseki. Case is 3 1/4" OD, rear clamped. I can't put pic into new computer, but will do so when I figure out how to live with 11. This thing is obviously new, I strongly suspect a repro part as dial paint is just too bright and the backlight is LED with 1/4" push on modern terminals. Mechanical drive. Face says: "Ferguson" in stylized script, "hours at 1500 RPM" in print above hour meter, 4 black, one white and one more black background fields on time drum, "tractor meter" in type below, below that 2:1 and in larger type following out edge of face "R.P.M. HUNDREDS" lining up with outer dial in RPM to 24 Speedo numbers shown in black/white/black background for high range gears 321 engine at 14, 75 and 5 with inner ring face in red, white, red background for gears low range 3,2,1 ending at 3.5, 2 and 1.3. There is a bar showing PTO 536RPM just under 1500 engine RPM and a second "STD BELT SPEED" at 20 (i.e. 2,000) RPM
Anyone able to tell me what this is for or where to go to find out what it is supposed to be?
/ Ferguson tach
Never mind. Found it on Amazon. Made in India by Vardia Enterprises to fit Ferguson 50.
If anyone in Canada needs or wants this just let me know. It is new and unused.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
Gehl Mix-All Grinder Mixer (A66408)
Gehl Mix-All...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2021 Bobcat T76 (A64126)
2021 Bobcat T76...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2015 Chevrolet Express Van (A62613)
2015 Chevrolet...
