Fence Post Backfill
/ Fence Post Backfill #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
A while ago there was a thread about using some kind of stone to back fill around a fence post versus using the ground dug up by the digger. The idea being the stone, once it settles by watering it or rain, is stronger than the dirt.
I can't seem to find it now. Does anyone remember this thread or tell me what stone to use?
/ Fence Post Backfill #2
Mike,
Don't know the posting you refer to but stone around the post will help defer water (longer life)as well provide more hard surface area thus more resistance to movement once enveloped with the surrounding dirt. I think pea stone or 3/4" stone would work well, mixed with the dirt will become harder to displace than the soil alone.
When planting posts here in NH we don't need to look for (or add) stone, as they are in abundance. I usually anchor the base where I want it with stone then back fill with the rest of the materials - stone and some dirt /w3tcompact/icons/smile.gif.
Carl
/ Fence Post Backfill #3
Mike, do you reckon <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=implement&Number=110377&page=&view=&sb=&o=&vc=1>this thread</A> is the one you had in mind? Pea gravel didn't work for me very well, but the theory sure sounded good./w3tcompact/icons/wink.gif
/ Fence Post Backfill #4
Mike,
It depends on what type of fence your putting in. If it's a privacy fence where it will catch a lot of wind, then you'll want to use concrete to glue the post in the ground.
If your putting up line post for for a cattle fence, then it's just what mother nature offers, because the cost of transporting material to backfill a couple miles of fence would be astronomical.
If your putting in a decorative fence such as a picket and you are in a wet area, then pea pebble would be a good fill. Remember, if you dig a hole and it fills with water, it doesn't matter what you use for fill, as it will be submerged in water also.
When setting any post in sand or gravely material I've found success in shoveling in a few inches of fill then using the shovel handle to pack it, then keep repeating the process untill the hole is full.
I remember back a few years, I was building a deck downstate and the local building officials would not let us use concrete for any of the deck posts. Their contention was that the concrete reacted with the chemicals used in treated posts (copper and chromium) causing premature failure of the posts. I don't know whether I buy that or not, but..."When in Rome...." We ended up digging the holes 4' deep, putting in a foot of pea pebble, packed the pebble and then set the post using the pebble as fill. Worked all right, the deck is still standing. I believe when you immerse a pole in concrete your not giving water a path to drain, so it sits around the pole for a long term and will eventually rot it whether it's treated or not. What I prefer, is to dig the hole, dump in a bag of ready mix concrete, stick in a garden hose and fill the hole with water, clean up the mess, go have a beer and watch your favorite broadcast,/w3tcompact/icons/smile.gif come back the next day and set the post and backfill with sand. The concrete serves as a footer and the sand as a stabilizer. This may be getting off the subject as far as fence posts are concerned, but I hope it helps.
/ Fence Post Backfill #5
Has anyone else used "road base" gravel mix for setting posts? Used it once for the mailbox post and it seemed to work very well. Tamped it down every few inches as we filled the hole. Seemed to hold the post very well yet with just a little elasticity which helped when the snow plows would throw the heavy wet snow while going by at 50mph.
2023 Kubota KX057-5 Midi Excavator (A66734)
2023 Kubota...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
Ford 340B Loader Attachment
Ford 340B Loader...
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
