FELTeeth
/ FELTeeth #1
thefuddr
Would it be advisible to add{bolt on} teeth to the bottom lip of a BX2200 FEL , to aide in busting out hard pan or clay? Good or bad idea guys?
/ FELTeeth #2
<font color=blue>Good or bad idea guys?</font color=blue>
A very good idea if you want to dig into anything other than loose material.
Bird
/ FELTeeth #3
I would not do that. I like to be able to back blade with the FEL and this would be impossible with teeth.
When faced with hard stuff, I loosen it up with the tiller which I use as ballast weight instead of the ballast box but you do have to be more careful when backing up.
Boy I miss the mirrors on my B7000,
Winnipeg, Manitoba
2001 BX2200 All Kubota FEL, Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
/ FELTeeth #4
I put teeth on the FEL of my BX2200 and I have made good use of them. As to the problem noted by one of the posters, the teeth on my FEL are bolted to the FEL in such a way that I can remove them quite easily.
OregonTom
/ FELTeeth #5
Woodstock,
I have a toothbar on my TC40D and am able to backblade with the toothbar installed. Instead of using the front edge of the bucket I just use the back edge. Took some getting used to initially but recently noticed that the owner's manual suggests using the back of the bucket.
Just my 2 cents...
DaveV
DaveV
/ FELTeeth #6
i have a detachable toothbar for my 2400. find it very useful for digging hard packed dirt or diging tree roots. if u need to back drag when it is on , use back part of bucket. if u really need to use front edge, 2 mim. and bar is off. very useful. well worth the price!!
/ FELTeeth #7
I put the chain over the teeth and used the FEL as a cherry picker to pull the 502 chevy out of my wrecked street rod. Does anyone want to buy a teenager?
/ FELTeeth #8
Excellent idea. It takes all of about a minute to put the tooth bar on (or off) - just two nuts (or is that too nuts...)/w3tcompact/icons/smile.gif
Do it - you'll be amazed how much faster the work goes in hard-packed ground.
Andy in NH
/ FELTeeth #9
Who sells them and how much?
Winnipeg, Manitoba
/ FELTeeth #10
I bought mine through my local dealer. For my 60" HD bucket on my 'bota it cost me about $300. Just had to drill a 5/8" hole on each side of the bucket and that was it. I think my bar was from SMC (out in the Dakotas if I remember right). I have the replaceable tips, though the thing is built so heavy I may never need to.
Andy in NH
/ FELTeeth #13
Umm...Dentist? Kust kiddin - try your dealer. Can't tell where you are but most will have replacement tips for backhoes and such. As for making up your own bar and teeth - others may know better then I - search on toothbars and see what you find.
Andy in NH
2025 32in. Tilting Bucket Mini Excavator Attachment (A64553)
2025 32in. Tilting...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
213089 (A64276)
213089 (A64276)
HARDEE 300 GALLON PULL TYPE SPRAYER (A64278)
HARDEE 300 GALLON...
