FELTeeth
/ FELTeeth #1
thefuddr
Would it be advisible to add{bolt on} teeth to the bottom lip of a BX2200 FEL , to aide in busting out hard pan or clay? Good or bad idea guys?
/ FELTeeth #2
<font color=blue>Good or bad idea guys?</font color=blue>
A very good idea if you want to dig into anything other than loose material.
Bird
/ FELTeeth #3
I would not do that. I like to be able to back blade with the FEL and this would be impossible with teeth.
When faced with hard stuff, I loosen it up with the tiller which I use as ballast weight instead of the ballast box but you do have to be more careful when backing up.
Boy I miss the mirrors on my B7000,
Winnipeg, Manitoba
2001 BX2200 All Kubota FEL, Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
/ FELTeeth #4
I put teeth on the FEL of my BX2200 and I have made good use of them. As to the problem noted by one of the posters, the teeth on my FEL are bolted to the FEL in such a way that I can remove them quite easily.
OregonTom
/ FELTeeth #5
Woodstock,
I have a toothbar on my TC40D and am able to backblade with the toothbar installed. Instead of using the front edge of the bucket I just use the back edge. Took some getting used to initially but recently noticed that the owner's manual suggests using the back of the bucket.
Just my 2 cents...
DaveV
DaveV
/ FELTeeth #6
i have a detachable toothbar for my 2400. find it very useful for digging hard packed dirt or diging tree roots. if u need to back drag when it is on , use back part of bucket. if u really need to use front edge, 2 mim. and bar is off. very useful. well worth the price!!
/ FELTeeth #7
I put the chain over the teeth and used the FEL as a cherry picker to pull the 502 chevy out of my wrecked street rod. Does anyone want to buy a teenager?
/ FELTeeth #8
Excellent idea. It takes all of about a minute to put the tooth bar on (or off) - just two nuts (or is that too nuts...)/w3tcompact/icons/smile.gif
Do it - you'll be amazed how much faster the work goes in hard-packed ground.
Andy in NH
/ FELTeeth #9
Who sells them and how much?
Winnipeg, Manitoba
/ FELTeeth #10
I bought mine through my local dealer. For my 60" HD bucket on my 'bota it cost me about $300. Just had to drill a 5/8" hole on each side of the bucket and that was it. I think my bar was from SMC (out in the Dakotas if I remember right). I have the replaceable tips, though the thing is built so heavy I may never need to.
Andy in NH
/ FELTeeth #13
Umm...Dentist? Kust kiddin - try your dealer. Can't tell where you are but most will have replacement tips for backhoes and such. As for making up your own bar and teeth - others may know better then I - search on toothbars and see what you find.
Andy in NH
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
Case IH DX25E Tractor (A66408)
Case IH DX25E...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
New/Unused 20x30 All Steel Carport (A65583)
New/Unused 20x30...
