FEL Tooth-bar - - one mo time
/ FEL Tooth-bar - - one mo time #1
Tdog
Platinum Member
SE Louisiana
BX22
I've read several posts about how much better the FEL digs with a tooth-bar. That's got my attention. When I bought my tractor & I asked about one, my dealer sorta went, 'huh'? And I was so excited about putting in the order, I did not pursue it.
I'm thinking about ordering one now - - problem is, I use the FEL a good bit to backdrag an area to smooth it. Isn't this a problem with a tooth bar? Is it something that I can bolt on & take off [relatively] easily?
FYI I just don't see many [any?] FEL's with tooth bars in this area. Wonder why? We don't have rocks, maybe that's why?
Thanks.
/ FEL Tooth-bar - - one mo time #2
They usually bolt onto the sides of the FEL with 2 bolts. Easy on, easy off. Do a search and you'll find loads of information. G
/ FEL Tooth-bar - - one mo time #3
You might try an EZATTACHMENTS landscaper toothbar. 18 teeth instead of 7-8. Of course, you will pay more for more teeth....but works pretty well with backdragging. See mine attached.
sassafraspete
/ FEL Tooth-bar - - one mo time #4
Yes you can remove it easily. I backdrag with mine on though and am happy with the results. As far as digging, You'll wish you had it sooner.
/ FEL Tooth-bar - - one mo time #5
TDog.
A tooth bar certainly is a big bonus as far as digging with a FEL goes . As for as smoothing /back dragging ... the back of the bucket works pretty fine . A big plus is the ability to drag brush . depending on the amount of forward curl , and the wieght of the tractor ,you can use the fel to loosen dirt ,and drag brush.
As to taking the tooth bar on and off ... It's two bolts .
I'd not be without mine !! John
/ FEL Tooth-bar - - one mo time #6
The first time I stabbed a tree and lifted it out of the ground I was sold on it. Worth every single one of those 45,000 pennies, would do it again in a heartbeat. Get the carbide replaceable teeth ($7 each).
/ FEL Tooth-bar - - one mo time #7
as the others have said get the removable toothbar, 2 bolts on and off, less than 2 min. helps with digging or lossening hard packed dirt, would not be with out it. /forums/images/graemlins/laugh.gif
/ FEL Tooth-bar - - one mo time #8
</font><font color="blue" class="small">( ....18 teeth instead of 7-8.....
sassafraspete )</font>
Wow /forums/images/graemlins/shocked.gif. That looks mean and aggressive!
/ FEL Tooth-bar - - one mo time #10
The toothbar can be of great use when back-dragging as well. By using the bottom of the teeth as a rake, you can get things very level in a big hurry because it loosens the humps, breaks up clods, and allows the dirt to flow through in a metered amount. Then, use the back edge and bottom of the bucket with the theeth curled up out of contact to put the final smoothing on.
I found it much easier to smooth 1-1/2" rock using the toothbar as a rake than using the bucket back edge. Quicker in sand as well, but sand is easy.
- Rick
/ FEL Tooth-bar - - one mo time #11
I'm new at this myself, but with two whole day's experience under my belt, I'll second what Rick says--a toothbar can be really useful for back-dragging. Remember that box blades, which are made to do this kind of work, have "teeth"--scarifiers, or whatever they're called. First you break up the soil, then you flatten it. With the bucket/toothbar you do it in two passes instead of just one...first with the teeth, then with the bucket, tilted up.
One thing I'm not sure of--I'll address this in a separate post--is how strong those teeth are. They look very strong, but it seems possible that they would break if you drag them with too much weight in packed soil/gravel.
Jim
Thanks to all - - think I'll see what Carver can do for me.
Good information.
/ FEL Tooth-bar - - one mo time #13
<font color="blue">One thing I'm not sure of--I'll address this in a separate post--is how strong those teeth are. </font>
JCA,
I did not see your separate post so I thought I would repond here.
My toothbar teeth are very strong. I don't worry about them at all. I have picked/pried large concrete pieces out of fill dirt dumped on my driveway, sometimes only using one tooth and never worried about it. I would call them indestructable if I could spell the word... /forums/images/graemlins/blush.gif
I have attached a photo so you can get the feel of what I am talking about... /forums/images/graemlins/smile.gif
2008 FORD E- 350 S/A MOBILE PET GROOMING VAN (A59914)
2008 FORD E- 350...
Towable Pump (A64553)
Bush Hog 285 3-Pt Rotary Cutting Mower (A66285)
Bush Hog 285 3-Pt...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
