FEL Tooth-bar - - one mo time
/ FEL Tooth-bar - - one mo time #1
Tdog
Platinum Member
SE Louisiana
BX22
I've read several posts about how much better the FEL digs with a tooth-bar. That's got my attention. When I bought my tractor & I asked about one, my dealer sorta went, 'huh'? And I was so excited about putting in the order, I did not pursue it.
I'm thinking about ordering one now - - problem is, I use the FEL a good bit to backdrag an area to smooth it. Isn't this a problem with a tooth bar? Is it something that I can bolt on & take off [relatively] easily?
FYI I just don't see many [any?] FEL's with tooth bars in this area. Wonder why? We don't have rocks, maybe that's why?
Thanks.
/ FEL Tooth-bar - - one mo time #2
They usually bolt onto the sides of the FEL with 2 bolts. Easy on, easy off. Do a search and you'll find loads of information. G
/ FEL Tooth-bar - - one mo time #3
You might try an EZATTACHMENTS landscaper toothbar. 18 teeth instead of 7-8. Of course, you will pay more for more teeth....but works pretty well with backdragging. See mine attached.
sassafraspete
/ FEL Tooth-bar - - one mo time #4
Yes you can remove it easily. I backdrag with mine on though and am happy with the results. As far as digging, You'll wish you had it sooner.
/ FEL Tooth-bar - - one mo time #5
TDog.
A tooth bar certainly is a big bonus as far as digging with a FEL goes . As for as smoothing /back dragging ... the back of the bucket works pretty fine . A big plus is the ability to drag brush . depending on the amount of forward curl , and the wieght of the tractor ,you can use the fel to loosen dirt ,and drag brush.
As to taking the tooth bar on and off ... It's two bolts .
I'd not be without mine !! John
/ FEL Tooth-bar - - one mo time #6
The first time I stabbed a tree and lifted it out of the ground I was sold on it. Worth every single one of those 45,000 pennies, would do it again in a heartbeat. Get the carbide replaceable teeth ($7 each).
/ FEL Tooth-bar - - one mo time #7
as the others have said get the removable toothbar, 2 bolts on and off, less than 2 min. helps with digging or lossening hard packed dirt, would not be with out it. /forums/images/graemlins/laugh.gif
/ FEL Tooth-bar - - one mo time #8
</font><font color="blue" class="small">( ....18 teeth instead of 7-8.....
sassafraspete )</font>
Wow /forums/images/graemlins/shocked.gif. That looks mean and aggressive!
/ FEL Tooth-bar - - one mo time #10
The toothbar can be of great use when back-dragging as well. By using the bottom of the teeth as a rake, you can get things very level in a big hurry because it loosens the humps, breaks up clods, and allows the dirt to flow through in a metered amount. Then, use the back edge and bottom of the bucket with the theeth curled up out of contact to put the final smoothing on.
I found it much easier to smooth 1-1/2" rock using the toothbar as a rake than using the bucket back edge. Quicker in sand as well, but sand is easy.
- Rick
/ FEL Tooth-bar - - one mo time #11
I'm new at this myself, but with two whole day's experience under my belt, I'll second what Rick says--a toothbar can be really useful for back-dragging. Remember that box blades, which are made to do this kind of work, have "teeth"--scarifiers, or whatever they're called. First you break up the soil, then you flatten it. With the bucket/toothbar you do it in two passes instead of just one...first with the teeth, then with the bucket, tilted up.
One thing I'm not sure of--I'll address this in a separate post--is how strong those teeth are. They look very strong, but it seems possible that they would break if you drag them with too much weight in packed soil/gravel.
Jim
Thanks to all - - think I'll see what Carver can do for me.
Good information.
/ FEL Tooth-bar - - one mo time #13
<font color="blue">One thing I'm not sure of--I'll address this in a separate post--is how strong those teeth are. </font>
JCA,
I did not see your separate post so I thought I would repond here.
My toothbar teeth are very strong. I don't worry about them at all. I have picked/pried large concrete pieces out of fill dirt dumped on my driveway, sometimes only using one tooth and never worried about it. I would call them indestructable if I could spell the word... /forums/images/graemlins/blush.gif
I have attached a photo so you can get the feel of what I am talking about... /forums/images/graemlins/smile.gif
John Deere 950 Tractor (A65579)
John Deere 950...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
Anco 3Pt Ditcher (A66408)
Anco 3Pt Ditcher...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59914)
2021 UTILITY VS2DX...
