FEL Stress
/ FEL Stress #21
</font><font color="blue" class="small">( broken welds on skid steer loaders due to the stress of running them fast over rough terrain <font color="red"> while loaded. </font> )</font>
I think "while loaded" is a sure way to guarantee damage. It's like using a heavy jackhammer on the welds. I am a little surprised it happened on a skid steer, just because of their geometry. But, I guess weight and shock loads don't really go together no matter what the geometry.
/ FEL Stress #22
One of the things that annoys me the most with a sale of a unit is when the purchaser comes in and wants (this) loader. Why because it lifts more than the factory loader! Who knows how much a front loader and AXLE for a perticular tractor will handle better then the guys that built it!!!!!! We've done that and had to fix and fix and fix the same pieces! It comes from the customers pocket after about the third time which is normally just before it goes out of warrantee. Sorry guys just a problem area and I got carried away!
/ FEL Stress #23
<font color="blue">Allo/Quickie (Spel?) and Buhler/Allied are two that I know of.Chuck M. </font>
I thought at one time, I have read where Quicke had a shock absorber on the larger loader, I can't find anything on it now. I don't know if I would call it a accumulator or not.
/ FEL Stress #24
Nick,
I think any appliance will put some type of stress on your tractor. But stress is the whole reason we buy a tractor and loader. You see the stress that use to be on me is now on the tractor. We pay good money for these rigs to work in our favor. Any cracks/stress is just battle scars. On the FEL, ballast will take a lot of stress off the tractor and if we operate it under normal conditions it will last a long time. Being around equipment I have seen things like, let's drive as fast as we can into that dirt pile and see how big of a scoop we can get or how much dirt will fly. This is where you will see stress not only on the loader but on the tractor also. Engineers designed this stuff and I am a firm believer in add ons being of the same manufacture for most equipment.
I see your from Minnesota, what part? I am from Rochester here.
murph
/ FEL Stress
Cannon Falls. We're pretty close. I hate when I see equipment operators drive real fast to plow into the pile. Don't know why but thats probably why it's so hard to find a good used skid steer these days.
/ FEL Stress #26
</font><font color="blue" class="small">( [We've done that and had to fix and fix and fix the same pieces! It comes from the customers pocket after about the third time which is normally just before it goes out of warrantee. Sorry guys just a problem area and I got carried away! /quote]
Don't you mean it comes outta their estate?
You are right to moan about that point..
/ FEL Stress #27
Most of the Wheel loaders and backhoes are installing ride control as an options these days... It is basicly a gas charged accumulator.
/ FEL Stress #28
JerryG- Yes they call it a cushion ride, shock absorber etc., but it is done with a nitrogen charged accumulator. This concept has been used on combines, for years, for header bounce or shock absortion, Hesston has used it on their SP windrowers since the introduction of the new models starting in 87ish. Oil has no give, for a lack of a better word, the gas charged cylinder gives or cushions the load depending on the pressure of the charge.
Chuck M.
/ FEL Stress #29
CMunger,
I guess I just have a problem with calling it a accumulator.
/ FEL Stress #30
Jerry- I can see why you would, I just have never given it a thought, it's just what it has been called for a long time.
Dictionary;1.one that accumulates, 2;a circuit or device, 3;a storage battery or storage cell.
Chuck M.
/ FEL Stress #31
</font><font color="blue" class="small">( I just have a problem with calling it a accumulator. )</font>
Jerry, I'm not sure I understand your "problem" with the term, accumulator. In the hydraulic systems of many airplanes, accumulators provide a damping effect for the hydraulic system. They maintain pressure or absorb shock in the system when sudden surges are felt due to activation of a large cylinder like on the landing gear. The british call them "capacitors" and they function to hydraulics exactly like capacitors do to electric/electronic circuits. I can see that these are really accumulators since they use a precharge of nitrogen. That precharge would be just above the maximum lift pressure of the hydraulics so a spike or shock would be absorbed by the pressurized bladder. I just wonder if the engineer who came up with this method had experience in aircraft. /forums/images/graemlins/cool.gif
/ FEL Stress #32
I would like to reinforce the point that none of the ballast reduces stress on the tractor frame! It reduces stress on the front axle.
As for engine and transmission damage, I can't see what they possibly mean. Maybe from a possible rollover /forums/images/graemlins/cool.gif
/ FEL Stress #33
Slowzuki,
Not sure if this is what you are looking for on engine/transmission damage, but there have been cases of the loader stresses breaking transmission cases and bell housing to engine mounts. Some tractors have actually broken in half /forums/images/graemlins/frown.gif Not a common occurance, but it has/does happen.
/ FEL Stress #34
Slowrev, I know about the casting damage but ballasting only increases the stress on the castings. I was thinking maybe increased shock loading from unweighted tires spinning.
Lack of ballast could over load the front axle due to the much increased traction available there. This could damage the tranny or 4wd components. I fail to see how the engine could suffer.
Ken
/ FEL Stress #35
I was reading all this thread and I agree and disagree with some issues.
Not having ballast in the rear of the tractor will cause a moment; this is why you want ballast. It causes the tractor to “want” to turn counter clockwise. Using the ballast just makes the moments zero.
As far as a force goes, it does not matter if you have ballast or not. The force on the tractor is the same. Having 500 lbs in the front and 400 in back does not make a difference. The tractor does not care if it feels the front and rear weight, still feels weight not matter what you use.
Lastly, as far as welds and stress on the tractor; having the ballast will help lessen the stress on the front end but again it depends on the distance and the weight used. If you have 200 lbs 1-foot from the tractor, that is not as much as if it was 3 feet out from the tractor. You could figure it out pretty easily.
For example, on my BX22 if I had 450 lbs at a 45-degree angle out 6 foot from the loader pins that would cause a 1,900 lb force on the pins. If I used rear ballast @ 5 ft from loader pins I would need around 400 lb to equal the force. But that does not take into account the tractor weight either. So a 200 lb weight would be fine from a force standpoint. Also the changing loader angle will cause different forces felt along with if you are moving.
/ FEL Stress #36
Total down-force would remain the same, but down-force on the front axle is definitely reduced by putting the ballast aft of the rear wheels. It's the teeter-totter effect.
/ FEL Stress #37
I agree but 500 on front and 400 on back, you still have 500 no matter what is on the back. You can tell me "teeter-totter" but the tractor still feels 500 on front, period. The front axle will feel some # of weight based on distance from loader pins and weight in loader.
It (weight) is still there but the rear weight makes the tractor thinks it is not there but it is. Even using the example I stated, the loader pins still feel 500 no matter what is on the back. It is reduced but not much. Plus with the tractor weight and operator weight would make the force and moment much less. The weight on the front axle I would say, just throwing # out would be 30 to 40% less total weight at pins.
Again this is for a STATIC situation and not considering the tractor moving. Plus the laoder is not directly on the front but behind the front axle (near the operator by some delta) so really some weight should be subtracted from the total weight. I can figure this out on my BX22 if needed (quick and easy).
Let just throw out the (F) x (d) formula used in Statics. If what you say was true then; if I had 500 on front and 500 on back it would equal zero, but you just now added 1,000 lbs to the overal system. So from the 500 on the front I bet the front still feels 250 to 300 even with the 500 on back or 1000 overall. It is a no win and the front axle still feels in increase in weight. Do the ballast help, sure, but not much.
To close if the engineers designed these tractors so close that we need to worry about stresses on front end (not using their safety factor) they should be shot or fired. Basic design understanding.
/ FEL Stress
As for the stress on the engine one of the mechanics at the shop has an old 1957 Fordson Major Diesel. It needs a new engine or block assembley becasue the tractor at one point had a loader on it and the guy always rode the clutch. This forced a lot of stress on the engine and the thrust bearring fell out and then some how the block started to get worn down. I am not a mechanic and do not remember all he told me. It was something along those lines.
/ FEL Stress #39
</font><font color="blue" class="small">( It made a point that if you properly ballast the rear of your tractor it would reduce the weight on the front axle and distribute it more evenly upon the entire frame and both axles. )</font>
If you ballast the rear wheels, it should have no effect on the front axle load. If you apply your load behind the rear axle, e.g. a weigh box on the 3PT, then you increase the load on the rear axle in excess of the weight added, and unload the front axle.
If you unload the front axle by adding weight aft, you increase the bending stresses on the frame.
/ FEL Stress #40
If you have John Deere then you would tear up the loader before you hurt the tractor since the Deere loaders on the 4XXX series are pretty weakly mounted both to the tractor and to the bucket/forks. Mine is about ready to self destruct. I really wish I had bought a Kubota or a commercial machine. I would have expected the loader to last more than 530 hours especially since I have only used the loader for maybe 125 hours or so. I was impressed at first with how easy it was to remove and replace the loader and the bucket but those are the weak points in the design.
1991 Wilson Hopper Bottom Trailer (A66285)
1991 Wilson Hopper...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
3 Point Bale Mover (A65640)
3 Point Bale Mover...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A67147)
2018 INTERNATIONAL...
Steel Coils (A65640)
18' Pipe Gate (A66408)
