FEL protection
/ FEL protection #1
drynoc
Woodbridge
John Deere 1025R with FEL
I have a new 1025R with the FEL which I like very well. I haven't used the FEL yet except for a quick move of some mulch. But I know when I start work on leveling parts of the back yard that the loader will take a beating. Have any of you done anything to protect it, such as apply truck bed liner?
/ FEL protection #2
Not sure what part you are referring to? Are you talking about the loader bucket? Sure it will wear the paint off....but who cares.
I wouldnt put bed-liner in the bucket. It will make things dig harder, and more dirt will stick inside the bucket. As it comes from the factory.....its ready to play in the dirt without doing a thing to it.
/ FEL protection #3
Heavy duty leveling should be done with Three Point Hitch implements. A few Three Point Hitch levelers include: Land Plane Grading Scraper (LPGS), Box Blade and Rear/Angle Blades.
If your leveling work is moderate I suggest a Ratchet Rake bucket attachment, which will transfer abrasion from the bucket to the extended lower teeth on the Ratchet Rake.
Most used for tearing out brush, then piling the resulting debris, Ratchet Rake is also fine for moderate grading and small garden soil preparation.
You cannot DIG with a Ratchet Rake on the bucket.
Ratchet Rakes are sold by the T-B-N Store, button at top of this page. Delivery by UPS.
VIDEO: ratchet rake brush clearing - YouTube
Tractors are prime movers. Now you need tools, which for tractors are called implements when mounted on the Three Point Hitch and attachments when mounted on the FEL.
Do not plan to pick up a heavy load with the FEL without ballast of some sort on your tractor, usually weight mounted on the Three Point Hitch. If you pick up a heavy load with the FEL without counterbalance, your rear wheels will lift in the air.
Revise your T-B-N Profile adding your state and tractor.
/ FEL protection #4
If you are worried about scraping the paint off of the FEL bucket, yes it will scrape up the paint pretty quick. No, you don't need to do anything about it. If you like you can keep a matching spray can handy, and hit the upper areas with the rattle can once in a while. Don't bother with the bottom areas. As for dents in the bucket, you will get some. Just part of the deal.
/ FEL protection #5
Not to be wise guy,but having it both ways welllllll... hope you have lot of touch up paint.
/ FEL protection #6
You could always do what my grandparents did when they wanted to protect things...:laughing:
Only kidding!
Buckets are meant to be scratched...you'd never stay ahead of trying to keep paint on it!!!
/ FEL protection #7
Congratulations on the new tractor. On the bucket, lighten up. It will get scraped and worn. That's a badge of honor. If I went to a friend and saw a tractor with more than a few hours and untouched paint on the bucket, he'd never hear the end of it.
Only tip - if you are trying to lift with the bucket, be careful about wrapping a chain around the middle. You have enough lift capacity to bend the top edge of the bucket. (Don't ask how I know.)
/ FEL protection
Thanks for all the replies. Obviously, I'm a noob in the tractor business. Leveling requirements will be modest for the first year or so. I'll look into the implements such as the rake.
/ FEL protection #9
Learning how to level soil with a FEL loader takes some practice. Other 3pt implements are easier for a new person to get going with good results.
/ FEL protection #10
drynoc
:welcome: to TBN
Don't hesitate to ask more questions, and also to tell us about your experiences with the new tractor.
/ FEL protection #11
A bucket with no scratches would be nearly as bad as a construction worker with a new tool pouch. We would throw it on the ground, rub dirt on it, stomp on it, fill it full of rocks and beat on it, what ever it took to break it in. You don't want to look like the new guy with a shiny new tool pouch.... or bucket. :)
/ FEL protection #12
Weld a 2x2x1/4 angle to top of the balde & you will not bend the top edge. While you are at it, weld a chain hook at both ends & a 2" receiver tube in the middle (with a chian hook welded to the top of it). No you really can rig & lift things!
2019 Nissan Leaf 4 Door Hatchback (A66738)
2019 Nissan Leaf 4...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A66734)
2019 Cub Cadet...
2017 Ford F-350 Knapheide Service Truck (A66736)
2017 Ford F-350...
2012 KOALA BUMPER PULL (A67714)
2012 KOALA BUMPER...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
