FEL mounted plows?
/ FEL mounted plows? #41
/ FEL mounted plows? #42
Can't be too bad seeing as how Kubota is now offering them on their BX tractors.
/ FEL mounted plows? #43
4shorts, have you ever tried a snow pusher? The only place I miss my plow on the tractor is long roads where I have to wing the snow back. It will clear a parking lot way faster than a fixed blade and it is quicker than my V plow. CJ
/ FEL mounted plows? #44
Last winter I almost had a deal made with a Quebec company to purchase a hydraulic expandable snow pusher but after much consideration I opted out because although the pusher would be faster in wide open areas such as parking lots it would be a hindrance in other areas where I use my angle plow and I use my angle plow a lot so I didn't like the trade off and stuck with using what I'm used to. The other issue I had with the pusher was the fact it had a steel blade and my blade is of a poly material and the wet snow don't stick to it.
/ FEL mounted plows? #45
A V-plow would be a very good option for you. You can do everything with them. I ran one for the last 8 years commercial and it was the best decision I made next to not plowing anymore!! I know you tractor would push a 9' V with no problem. CJ
/ FEL mounted plows? #46
I'm getting pretty tired of plowing snow. Up early and get back to base late. The V plow is a great system but the blade in have on my tractor is a Polly plow and its paid for many years ago. Wouldn't like to put another $5000. Into another snow plow.
/ FEL mounted plows? #47
I converted an old Meyers 80" wide plow to fit on my tractor FEL. Made my mount so that the blade sits as close to the tractor as possible....pretty happy with the mount. Put a corssover valve on it to reduce problems with catching a corner. It works pretty well in my limited use so far....plenty of power.....but it does push the front end of the tractor over with heavy snow. I have industrial tires.....and have considered adding chains for the front to help with the side push.
sorry, no pics.
/ FEL mounted plows? #48
I hear ya, it is like being married to someone you don't like!! If, when I retire I will consider it again but for the time being no more. The only plowing I do now is myself, our local hall and push banks back with a large loader. I make more in one night with the loader than in a month of plowing. CJ
2022 EZ-GO ELITE...
Ground Protection Mats (A64194)
Ground Protection...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
Kubota ZD221 48in. Zero Turn Commercial Mower (A64194)
Kubota ZD221 48in...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A64556)
2014 Hyundai...
2000 Chevrolet Astro Passenger Van (A64194)
2000 Chevrolet...
