fel hydraulics knowledge
/ fel hydraulics knowledge #1
xmoikan
hello everyone i wonder if anyone know if the hydraylic pump of the kubota b6000 can afford cylinders for a fel and what cylinders should i find?i also want to know the pipe fitting for all the construction.i have no problem with the iron work but on hydraulics i have no idea
/ fel hydraulics knowledge #2
Welcome to TBN:D
I have no idea of the GPM or PSI specs for the hydraulic pump on your machine, If you can post them than we can offer a little more help. There is plenty of general information on hydraulics in the Hydraulics form if you look/search there.
my punp works to 18 lit/min but i dont know the pressure
the code of the pump is :
50507
580
GP-3127B
/ fel hydraulics knowledge #4
Ok, that equals 4.76 Gallons per minute. It will power a FEL, but without pressure specs we can't know the amount of lift you could expect.
