FEL Diagnosis
/ FEL Diagnosis
Here's the valve I ordered. It can be made to have PowerBeyond but I think that would require a replacement part.
My preference is to use the front pump and have the FEL separate from the 3PT. There are just a number of unknowns with the front pump. It does turn, but will it pump up pressure? I can't figure out what model it is so I have no idea what the volume should be. However, based solely on the hose size, it's probably 6GPM or more. I think it's using 3/4" hoses. It's certainly MUCH larger than the 3/8" that are currently plumbed from the diverter valve on the 3PT to my loader valve. I think I'd also need to plumb in a filter. Buried somewhere in my other thread I tried to explain the way that front pump is plumbed. The hoses simply go from the front pump to the reservoir and back. Which really makes no sense so maybe it doesn't work right and instead of tearing all that off, previous owners simply re-attached it so it wouldn't drag around and gave up on it.
At the moment it basically boils down to money. I'd really like to get this all setup on the front pump. But I don't know what parts work and what parts need replacing. I think I'll focus on figuring that out before going too far with the new valve. The hoses sizes between the front pump/system and the rear are pretty different so I don't want to buy a bunch of adapters just to test it out with the rear system only to turn around and change everything to the front pump. The back pressure that's so persistent in my system also has me concerned about damaging this new valve.
I might be able to find a few parts around my dad's farm to test out the pressure on the front pump. I have a single spool valve left over from that monstrous 3PT PTO pump I removed. I think all I really need is a relief valve and maybe a hose? I can hopefully put my pressure valve in the circuit to see if the front pump is good. If so, that's definitely the way I'll go.
/ FEL Diagnosis
I had some time, and help today, and figured out that the front pump on this tractor DOES work!
I'm going to layout a setup that will utilize the front pump to power the FEL. This system will have its own pump, filter, fluid, and reservoir. This will eliminate the issues of back pressure from the 3PT that I haven't figured out and will hopefully make the loader operate faster and be simpler to maintain and repair. The reservoir is already mounted so all I really need to do is figure out where/how to mount a filter (suction, pressure, or return line) buy the correct length hoses and get system flushed and mounted. While doing this I'll replace the hoses that lead from the loader valve to the fixed lines and a couple others.
It'll probably take me a few weeks to get everything sorted out, purchased, and attached but I'm very excited about the possibilities.
/ FEL Diagnosis #33
Thats good news!
How did you test it for sure? I know you had some rubber coupler that you fashioned up but did you use that to acutally develop pressure and work it with a load on it..or buy some couplers at the store or somethi9ng?
/ FEL Diagnosis
I canalized some hydraulic parts from the rear PTO driven pump for testing. All the plumbing on the front pump is 3/4". The reservoir to pump was already in place. I took the valve off the PTO setup and put that in between the pump and the reservoir. Using the rubber muffler bushing I cut to fit last time I used some 1/4" shear bolts to connect the hydraulic pump to the front engine mount. Using the big 3/4" valve I was able to watch fluid flow in a circle when the control was in neutral. When I moved the lever in either direction the pressure started climbing (I'd plugged the ports on that valve). I watched the gauge move up past 2500psi. I don't know what the pressure relief setting is on that valve but 2500 is more than enough for me so I backed it down.
What I need to figure out now is where/how to mount a filter and where to mount my new loader valve. Good problems to have ;)
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
Rhino DB150 (A57148)
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2012 HEIL (A60736)
2012 HEIL (A60736)
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
