FEL bucket orientation indicator
/ FEL bucket orientation indicator #1
JohnS
Platinum Member
Southern Tier NY
Jinma 284
Being a FEL newbie, and after practicing for about a hour on some gravel, I find it hard to determine the orientation of the bucket from the tractor seat. I remember reading about some indicators, but my searches have not found them. I would appreciate any links, pics, or other info on this matter, espicially any DIY homebrew ones.
JohnS
/ FEL bucket orientation indicator #2
Hi John
I have Kubota L35 and on the left-hand arm of the loader is a attached a tube, and inside this is a rod that is attached to the bucket link, as the bucket moves, the rod moves up or down inside the tube, and from the driving seat you can see it come in and out of the tube, and with a bit of practice you soon know exactly what position the bucket is in, it is very simple yet very effective. I'm sorry if this description is confusing, but I don't have a dig camera yet.
I think it is a kubota standard fitting so they may have a photo on their site
Regards
Chris
/ FEL bucket orientation indicator #3
John,
I don't know anything about the FEL on a Jinma, but on my front loader there is a plate on the top of the bucket, parallel to the bottom of the bucket that is visible from the seat. I strapped a half full 16 oz clear plastic Pepsi bottle to the plate. When the bucket was level so was the pepsi in the bottle. When this rig finally got knocked off, I had a good enough feel that it didn't get repaired. Maybe you could rig up something similar.
Al
/ FEL bucket orientation indicator #4
Thanks Al, The Jinma FEL does have a flat plate ontop of bucket. I will try this quick and dirty approuch. Follow-up with a tube and rod solution, at a latter date. Thanks.
JohnS
Erinie, Chris, Thanks. I think I have a good idea how this works and will try to figure out the best mounting position, etc. I quickly looked at Kubota and Deere sites, but could not identify a level indicator in any of the FELs I looked at. If anyone has a pic or link to one, that would still be great. I would like to make one of the rod and tube ones, but in the meantime, I am going to try Al's quick solution.
JohnS
/ FEL bucket orientation indicator #7
My New Holand TC 35 (16LA loader) has a rod with a notch in it (a small bend in the rod). The rod slides parallel to the loader arm as the bucket tilts...the notch sits on the support bracket when the bucket is level. When the bucket is tilted forward the notch slides forward, when it is tilted up the notched part of the rod is back. It helps align things when approaching a stump or log that I want to lift with the toothbar.
This sounds identical to the rod in the tube...with the addition of a surefire way to know where level is. Perhaps a stripe painted on the rod would accomplish the same thing.
Chas
/ FEL bucket orientation indicator #8
Here is a picture from the NH 16LA loader. As described eariler, when the notch is centered on the bracked, the bucket is level. Having used Green and Orange tractors, I find this one the easiest to use. Just my two cents...
Mark
Thanks, for this pic. Do you happen to have one that is shot from a few feet back. Kinda get an overview of the whole hook-up. Thanks.
JohnS
/ FEL bucket orientation indicator #10
Here is a view from a little farther back. I little harder to see. This is actually a pretty simple setup. You would just have to figure out how to attach the rod at the bottom on yours. The bracket is held on by a u-bolt, it's just a piece of metal with a hole for the rod to slide through. Good luck...
Mark
/ FEL bucket orientation indicator #11
The picture Mark posted of the 16LA loader level indicator is similar to what Woods uses on their loaders (or at least on my model 1012). I like it better than the "rod in tube" method. The tricky part may be in getting the bends just right so that it sits in the notch when the bucket is level.
Mark, Thanks I got the idea now. The pic varified what I was interepting from the textual descriptions. Thanks for taking the pic and the quick response.
JohnS
/ FEL bucket orientation indicator #13
John:
You'll find all the indicators in the world arn't as good as lots of seat time. Thats the only thing that will do it.
/ FEL bucket orientation indicator #14
John Mc,
Its not that tricky to get the bend in the rod set to the correct position. Just get the bend close and then loosen the nuts on the u-bolt that holds the metal bracket and then slide the bracket to the correct position. Hopefully this makes sense, looking at Wood Dawg's first photo may clarify my explanation. I have this setup on a TC40D and even my 9 year old daughter gets the bucket level.
DaveV
Agree, just trying to reduce the number of hours of seat time. My first couple attempts were pretty funny. I'd think I have a bunch of gravel in the bucket, but when I dumped it just a pail full of rocks came out! Glad I was off on a more secluded spot. Don't want my neighbor laughing so hard he might hurt himself /w3tcompact/icons/smile.gif
JohnS
OK TRUCK & TRAILER SALES PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
OK TRUCK & TRAILER...
Set of 4 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 4 Unused...
2013 Dodge Avenger Passenger Car, VIN # 1C3CDZCB4DN759234 (A66738)
2013 Dodge Avenger...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
TIRE RACK WITH TIRES (A67714)
TIRE RACK WITH...
2012 INTERNATIONAL PAYSTAR 5900I (A67714)
2012 INTERNATIONAL...
