Fastest, with the wide cut?
   / Fastest, with the wide cut? #11
The Kubota F2680 or F3080 with the 72" cut is faster than any ZTR. Course top speed on either can only be done on pavement since full speed on either would cause nose bleed and Kidney damage but the F is clocked at a faster speed.
   / Fastest, with the wide cut? #12
if time on task is the top priority, just go ahead and hire it out....sit in your lawn chair and watch. & don't bother about motor head questions...unless you're in the bidness....enjoy
   / Fastest, with the wide cut? #13
Yep, I can recommend that style, I like a steering wheel better than levers. Get 4WD if you have hills.
Got mine on eBay, same style, TORO 325D 72" deck.
   / Fastest, with the wide cut? #14
2020 DRAGON ESP...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
2020 Case 5550 Trident (A56438)
2020 Case 5550...
2000 Morbark Towable Brush Chipper (A59228)
2000 Morbark...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
