FarmTrac Troubles
/ FarmTrac Troubles #1,901
Bill, the engine in your tractor is Daedong (KIOTI) and the chassis is LS, If you have an LS dealer in your area, check with them, we can ship them UPS to you also if needed. We handle both LS and KIOTI.
/ FarmTrac Troubles #1,902
I purchased a Farmtrac 8075 DT 2/24/10 and have found when the air conditioner is running I have condensation/water running into the cab and over the switches. I opened up the top of the cab and it looked to me like some hoses were missing to direct the water down the cab posts. I connected hoses but that did not fix the problem. Any suggestions? :confused2:
The hoses you are talking about connect to the drain pan under the evaporator. I assume that they are all in good working order. If conditioned air is getting into the roof compartment, condensation will take place on any of the metal items. That would be mainly moisture laiden on the metal and should not be flowing water. The seals in the evaporator housing
compartment must be leaking causing the condensation. Trac
/ FarmTrac Troubles #1,903
I haven't looked at this forum for a long time. I have a little Farmtrac 270DTC that I bought used several years ago, and it is dependable as a rock so far. I quit trying to keep up with what was going on with the company long ago. Where do I go for filters and preventive maintenance parts now?
Thanks,
Bill in Arkansas
Look for a LS Tractor dealer.
/ FarmTrac Troubles #1,905
I have a friend who owns a Montana LS 2740 with some PTO problems, Do you know anyone who can help?
Steve
678 378-4148
/ FarmTrac Troubles #1,906
HEY TAX---- AND BLUE have they got them there clams cook in the island state yet?????------is anyone suppling escort parts for those former farmtrac from india?
/ FarmTrac Troubles #1,907
Oughta be coming to a boil any day now Red,Who knows what the heck punjabs liable to do??:laughing:
Taxpayer
/ FarmTrac Troubles #1,908
Taxpayer
what are they using to cook----e the clams a cigar----- lighter????? at that rate someone is "libable" to get burnt----oh wait----a lot of dealers have already got burnt------
/ FarmTrac Troubles #1,909
RNF,
Sorry for the long absence. Although little has been heard from me lately, I haven't given up sniffing the trail--doing some background stuff. Long story there! Hope to have a few days in Aug to scratch around a bit.
Matter of fact, the time is nearing when I will be in your neighborhood. We will join forces with Taxpayer and...bad guys will have much to fear.
Like Superfriends? I'll spare the tights but re-double the skills and surly attitude.
Best,
--b
/ FarmTrac Troubles #1,910
I have a friend with a 555dtc that has this problem........said he thought the brakes dropped and is blocking oil flow.......pics and any help with be appreciated.......are seals needed for repair and if they are where can we get them?
Thanks for any help.......tractor only has 47 hours!!
Resurrecting this thread! It looks like our rear axle brake camshaft boots are leaking (and they are leaking a stream) from age and weather. We don't think that we had an overpressure problem. The boots have cracks along each of the folds that were created by the motion of applying the brakes. We've gotten new boots from our tractor dealer. Our dealer could fix this but we don't have a trailer to transport the trotor to them. I'm not sure that we are up to doing what longtrman said with the hole drilling to keep the hydraulic fluid level lower. Does anyone have a shop repair manual for this tractor from which they can scan in the pages for how to replace these boots and the specs on torques, special alignments, etc.? We found a manual online for a mere $1,000 (actually $999) but we do not have a mere $1,000 laying around to shell out..........
/ FarmTrac Troubles #1,911
I cannot find the thread What are the brake problems That Mscott is talking about. You can download the service manual from sundowner for like $80. I have it. I will try to find it. It is way to big to send over an e mail. I could probably send a disk through the mail.
/ FarmTrac Troubles #1,912
Wow, Clint S, we don't need the whole manual, just the parts that tell us how to replace that boot. Hope you can find your manual and find that info. Thanks for the heads up about Sundowner. If pages you find prove to be a help, we will probably go to Sundowner to download the whole manual! :D
/ FarmTrac Troubles #1,913
There is no real info on how to replace the boots just an exploded parts break down,.
/ FarmTrac Troubles #1,914
Thanks, Clint, we already have the the exploded view of all the parts along with a sheet that tells what each part is. Thank you for taking the time to look into it.
/ FarmTrac Troubles #1,915
Probably a little late but changing the boot is not that hard. Although it could have been designed a little better. First jack up the rear of the tractor. Remove the rear wheel. Take the brake linkage from the pedal loose. Remove hydraulic line running to rear brake hub. Remove the bolts holding the hub to the rear axel ( I think there is 9 or 10). Remove the clamp and the 2 bolts holding on the boot. Pull the brake hub and axel shaft out of rear axel housing. Careful it is heavy. You do not have to remove it completely if you don't want to just prop it up on a sturdy block. You just need it far enough out to get the brake shaft loose and remove the boot. Then put it all back together. Before you reconnect the linkage make sure the brake shaft is locked back in to the brake hub or you will find you have no brakes on that side. Just turn the shaft back and forth till it locks in.
/ FarmTrac Troubles #1,916
Thanks, Swamptractor. Your reply is not late and is a great help. We've been trying to stop the leaking with various tapes and coatings (while trying to find out how to replace the boots) but the hydraulic fluid eats through, or softens up, everything we've tried. We did not want to get into a situation where we would be ignorant of things to look out for, or be careful of, and then screw up the replacement job and have to wait for a part or get a special tool.
/ FarmTrac Troubles #1,918
Ten months later and we have replaced the brake boots WITHOUT REMOVING THE WHEELS. Additionally, we fabricated a moveable covers out of a truck tire inner tube to protect the boots from damaging sun rays. Brakes works great! Hydraulics work great! And we're not buying hydraulic oil like it is going out of style!
/ FarmTrac Troubles #1,920
Does anyone know what the status is of Textron (Escort) 665TDC?
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
