Factory Tips From Power Trac
/ Factory Tips From Power Trac #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
Looking at Moss Road's comment on the factory tips that people pickup by taking the class and talking to PT reps, I decided to start this thread.
What factory tips have you picked up?
One that just sprung up - Engage the power take off at idle and then rev up the engine.
/ Factory Tips From Power Trac #2
velcro a piece of tarp underneath the lifting arm so when you are using the tiller or stump grinder or other device will stop most of the debris from hitting the hoses.
And keep it out of your face.
/ Factory Tips From Power Trac #4
I am not visualizing the piece of tarp velcroed underneath the lifting arm. Anyone have a picture?
Dale
When tightening the trencher drive sprocket nut get a special socket from Power Trac, use lock tight on the threads and the air impact wrench.
/ Factory Tips From Power Trac #6
Did we ever get the size of the nut for the Trencher, et al? I think I'm going to be replacing seals on the Trencher, Trench filler, Post Hole Digger, and Tiller this Winter.:rolleyes: I was thinking of building my own wrench-socket-nut remover, since this will probably be done over some period of time. I would buy a nut and build the "remover" from there.:confused:
Power Trac gave me a nut when I bought the new drive sprocket. It is either a custom nut or it has been machined from a standard nut. I suggest you buy the nut from PT and then machine your own socket. The nut has got to be pretty cheap.
Be sure to use locktite on the threads and get it tight.
/ Factory Tips From Power Trac #9
But then you can't see what the Stump Grinder blade is cutting!!
Reverse the blade to throw the chips forward, and you can see what you are doing, and the chips won't hit you or the hoses!!
My blade will not reverse.
/ Factory Tips From Power Trac #11
Hey welcome back Fourteen! It's been a long time since your last post or thread. Where have you been? I reversed my stump grinder and it does work a lot better for flying chips. I also mounted a steel trailer fender on the grinder top and that helps a lot as well.
/ Factory Tips From Power Trac #12
""Where have you been?""
I've had some problems that have demanded most of my attention. Hope I can catch up!
""I also mounted a steel trailer fender on the grinder top and that helps a lot as well.""
I was considering that for mine, but used the flexible tire tread instead. Glad the fender works for you. Anything you can do to control the flying dirt and chips is a huge improvement!
/ Factory Tips From Power Trac #13
Glad you're back. Without someone willing to voice some "strong opinions" from time to time, this forum was getting a little boring. :) Now, about this idea of reversing the wheels....
/ Factory Tips From Power Trac #14
I was told during the class at Power Trac to tighten the big nut between the front and back halves of the PT every eight hours of use. It takes a 1 13/16 inch wrench. These are available at Northern Tools for about $20.
Add two extra bolts to the rough cut mower disc in the empty holes to keep the blades from getting hung up on the center hub. Mine did not already have these. I think the new ones do.
/ Factory Tips From Power Trac #17
Problem: The bolts will be too short! The blade will hit the bolt head, damage the bolt head, then ride up on top of it, and jam!
Solution: Screw a hex nut onto the bolt tightly against the bottom of the bolt head. Install the bolts. Now the blade will strike the side of the nut, and freely swing back into position!
/ Factory Tips From Power Trac #18
I tried that and I sheard them off, too. But it was a longer period of time between having the blades go over each other VS just having the bolt head there. I have learned to take a sledge hammer with me every time I brush hog. I use it to knock the blade off of the other blade when they get stuck together.
I have added 4 or 5 washers under the bolt. This helps, but is not perfect. Perhaps we should (or PT) weld an extension to the center hub. Does anyone have a better suggestion to improve this. I think we need something that has shock absorbing featers. How about welding a spring to the bolt head? It would give without breaking. Any thoughts on this.
/ Factory Tips From Power Trac #20
Each time my bolt breaks and the blade goes flying off into the sun-set, I think that confirms that not much will stand up to that mass of swinging metal. I just shrug it off, locate the blade, get out the impact hammer and extract the bolt from the backside of the hub. I have not mastered the EASY-OUT method and would like to do so.
Dingo Ditch Bucket (A61567)
Dingo Ditch Bucket...
Mini Metal Donkey Statue (A61569)
Mini Metal Donkey...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
JOHN DEERE 7320 TRACTOR (A62130)
JOHN DEERE 7320...
