Factory Tips From Power Trac
/ Factory Tips From Power Trac
If the blade hits a sudden stop like the added bolt, then the normal bolt holding the blade on is subjected to a tremendous stress. If it hits a spring the speed could be reduced over some distance (say an inch or so), reducing the forces by a huge factor.
/ Factory Tips From Power Trac #22
You are on the right track - I tried the washers on a bolt and bent some blades on my 1430. After some trials, found that a piece of truck tread makes a nearly indestructable bumper. Find a chunk along your favorite highway (wear gloves - lots of steel strands) or just borrow an old tire. To make washers use a 2.5 inch holesaw and a strong 1/2" drill, lots of lube (armorall or detergent/water) (it helps to drill from each side) - mine have a lot of steel in them and are about 1.5" thick. Drill a 1/2" hole through the rubber piece after you get it out of the holesaw - put a thick washer on the bolt and drive it through the rubber "washer" and install two of these into the spare holes on the brush cutter. Compress the rubber washers a quarter inch or so to make them really firm. You will, now have crash-free starts and stops, and the impacts from hitting solid objects are much reduced. If you find you are breaking or bending the bolts holding the rubber "washers" when you hit objects with the center of the mounting drum, try compressing the washers more. I have not broken any bolts or bent any blades since installing these.
/ Factory Tips From Power Trac #23
I think you have a good idea in using tire rubber in your design. Well thought out and practical.
Excellent idea.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
2012 Volkswagen CC Sedan (A61569)
2012 Volkswagen CC...
INTERNATIONAL 454 TRACTOR (A62130)
INTERNATIONAL 454...
(INOP) YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A62129)
(INOP) YANMAR...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
