Factory engine oil filter like it was welded on
   / Factory engine oil filter like it was welded on #1
thadri
Kubota bx23s
In the process of a 50 hour service oil change, drained oil and I can遞 get the factory oil filter off!! Tried a filter socket already, letting some PB catalyst soak in overnight, but seriously it逞エ like it was welded on in the factory!!! Help!!
   / Factory engine oil filter like it was welded on #2
They are on good and tight sometimes , you turning it the correct way ...
Been trying to turn counter clockwise assuming that is correct
   / Factory engine oil filter like it was welded on #4
YES...
   / Factory engine oil filter like it was welded on #5
Do you have a regular filter wrench also try both at the same time
   / Factory engine oil filter like it was welded on #6
Sometimes a big pair of channelocks, is the only thing, cause it will bite without destroying the filter. But there is the large screwdriver through the middle that should work.
   / Factory engine oil filter like it was welded on #7
I had the same problem on my Kubota- ended up using a BIG pipe wrench - worked great. Came right off. I BENT 1 filter wrench and broke a 2nd one before moving to the pipe wrench.
Good luck
   / Factory engine oil filter like it was welded on #8
Of course new filter smear a little oil on gasket. Factory sounds like they didn't do that.
   / Factory engine oil filter like it was welded on #9
You Kando anything with a pipe wrench! Sometimes a long pipe on handle! tapatalk_1559050859006.jpg
   / Factory engine oil filter like it was welded on #10
PB is for rust/corrositon. I've seen the stuff swell o-rings. Maybe you'll get lucky and it will turn the rubber gasket to mush instead of swelling it up and making it worst!
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2007 Hannay reels Hose Reel (A54865)
2007 Hannay reels...
John Deere 6120E (A50323)
John Deere 6120E...
22ft Rollback Flatbed Body with Winch (A55852)
22ft Rollback...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
