Factory engine oil filter like it was welded on
   / Factory engine oil filter like it was welded on #21
I have used a craftsman strap wrench when all else fails, been worth the 20 bucks many times over that I spent on it almost 40 years ago
Ah yes, those strap wrenches come in really handy, I have two of them. I have arthritis in my hands, good hand strength but too much pain to break loose jar lids at times, that's when I go get the strap wrenches...one on the jar, the other around the lid.
   / Factory engine oil filter like it was welded on #22
LOL> I actually considered breaking mine out last week to open a large jar of sauerkraut, but it was in the barn, and I was in my kitchen, I persevered and finally got the jar open
   / Factory engine oil filter like it was welded on #23
Dedicated oil filter pliers the correct size. and/or the strap wrench.
In some instances both can be used together. Make sure the strap wrench strap is as close as possible to the engine.
I try real hard not to punch a hole in them to use a screwdriver. Sometimes it just rips the filter housing leaving not much to grip anymore.
   / Factory engine oil filter like it was welded on #24
In the process of a 50 hour service oil change, drained oil and I can遞 get the factory oil filter off!! Tried a filter socket already, letting some PB catalyst soak in overnight, but seriously it逞エ like it was welded on in the factory!!! Help!!
Do you have an update? Have you gotten the filter off?
   / Factory engine oil filter like it was welded on #25
   / Factory engine oil filter like it was welded on #26
He may be out in a field stacking pallets
   / Factory engine oil filter like it was welded on #27
Maybe working on that nasty stripped drain plug?
   / Factory engine oil filter like it was welded on #28
Wow. I've never had that happen, but it would sure be a mess. Thanks for the caution.
   / Factory engine oil filter like it was welded on #29
Punching the filter with a screwdriver idea probably should go in the "Dumb Things I've Done" thread.
I did that ONCE. On my '69 Dodge the filter was stubborn; no pre-install oil on the seal... Great idea - just punch it with a screw driver and it'll come right off.
BONK - all it did was rip off the bottom part of the filter! I spent the next 3 hours with a small chisel plunking away at that filter, trying to get it to move just a little bit. And that was outside on the ground on very cold ground.
That was only half the dumb part - I later found out that the entire filter housing was removable with 4 very easy to remove bolts. Experience is a very valuable tool.
   / Factory engine oil filter like it was welded on #30
In the early 80's I did the first oil change on my mothers new Nova. The filter was on like it was welded too.
Every possible wrench type was used, until the filter canister finally collapsed.
Then, the screwdriver through the canister technique was applied, which went no where fast.
After removing the entire canister, only the mounting flange left. I also attempted to use a pipe wrench on the flange, but there was not enough there to grip.
I finally used an air chisel too, with a blunt bit in, it to "unscrew" the flange. That was a slow process, because I had to use care not to to damage the pump.
I still cringe when I have to do a first oil change.
You would think even a trained animal could properly do a simple task like this in the factory. But, factory labor, is often unskilled labor. And, these are no doubt tightened with some sort of mechanical device. So, if the person doing it is ignorant to how tight it should actually be, guess what can happen?
I saw many other examples of this kind of thing, in over 40 years of servicing vehicles.
The worst example of this I dealt with was on a zero turn mower, where I spent the better part of 2 days cussing, and running around to get different tools, while trying to take a brake drum off.
It was attached to a tapered spindle, with a single nut. Should have been a simple task. :laughing:
After no luck trying to remove the nut with a 1/2", and then a 3/4" impact, a 1" impact was brought in, which still labored to remove the nut. This left the brake drum pressed on the tapered spindle so tight, it resisted tons of heat, and multiple attempts with different types of pullers using a 6' long bar to turn it, as well as hours of banging on it with a large slide hammer, before finally relenting.
2015 Ford Focus (A51694)
2015 Ford Focus...
MAHINDRA 1635 TRACTOR (A54756)
MAHINDRA 1635...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2017 Freightliner MT55 Box Truck (A55788)
2017 Freightliner...
John Deere 853 20ft Corn Head (A55301)
John Deere 853...
