Factory engine oil filter like it was welded on
   / Factory engine oil filter like it was welded on #1
thadri
Kubota bx23s
In the process of a 50 hour service oil change, drained oil and I can遞 get the factory oil filter off!! Tried a filter socket already, letting some PB catalyst soak in overnight, but seriously it逞エ like it was welded on in the factory!!! Help!!
   / Factory engine oil filter like it was welded on #2
They are on good and tight sometimes , you turning it the correct way ...
Been trying to turn counter clockwise assuming that is correct
   / Factory engine oil filter like it was welded on #4
YES...
   / Factory engine oil filter like it was welded on #5
Do you have a regular filter wrench also try both at the same time
   / Factory engine oil filter like it was welded on #6
Sometimes a big pair of channelocks, is the only thing, cause it will bite without destroying the filter. But there is the large screwdriver through the middle that should work.
   / Factory engine oil filter like it was welded on #7
I had the same problem on my Kubota- ended up using a BIG pipe wrench - worked great. Came right off. I BENT 1 filter wrench and broke a 2nd one before moving to the pipe wrench.
Good luck
   / Factory engine oil filter like it was welded on #8
Of course new filter smear a little oil on gasket. Factory sounds like they didn't do that.
   / Factory engine oil filter like it was welded on #9
You Kando anything with a pipe wrench! Sometimes a long pipe on handle! tapatalk_1559050859006.jpg
   / Factory engine oil filter like it was welded on #10
PB is for rust/corrositon. I've seen the stuff swell o-rings. Maybe you'll get lucky and it will turn the rubber gasket to mush instead of swelling it up and making it worst!
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
Hose Reel (A55758)
Hose Reel (A55758)
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
CATERPILLAR 255 SKID STEER (A52705)
CATERPILLAR 255...
