Factory engine oil filter like it was welded on
   / Factory engine oil filter like it was welded on #12
I have done well with a chain wrench, or an impact chisel on the base of the hydraulic filters. I doubt the engine oil filter has the same slotted base though.
   / Factory engine oil filter like it was welded on #13
Crescent oil filter slip joint pliers. Has made my life easier.
Had a canister fuel filter loosen while pulling the camper north Texas and lost 1/2 tank of fuel going down the road. Kinda over tighten to fix beside the road. Pliers got if off when I got home.
   / Factory engine oil filter like it was welded on #14
What nobody mentions - the factory installed filter is tightened down by a 900# gorilla - then they paint the frame, including the filter. The gorilla plus the dry paint = PITA. At my 50 hour service - I knew what was coming. Used a LARGE pipe wrench - sweet as apple pie.
   / Factory engine oil filter like it was welded on #15
........then you add that on some equipment, you can barely even see the filter let alone get a good wrench on it.:mad:
   / Factory engine oil filter like it was welded on #16
I have used a craftsman strap wrench when all else fails, been worth the 20 bucks many times over that I spent on it almost 40 years ago
   / Factory engine oil filter like it was welded on #17
I've had this happen on lots of different kind of engines when they are new. I've had to drive a screwdriver through some and twist them that way. Be sure to check that the rubber gasket wasn't stuck hard to the metal when it does let go. Then I always smear a little grease on the rubber gasket of the new one and it doesn't have to be *too* tight.
   / Factory engine oil filter like it was welded on #18
Had the same issue with the oil filters on a 450hp Cummins diesel I once owned. The problem persisted even with the filters I installed that were only hand tight. Finally figured out the oil pressure when the engine was running was enough to cause the thin metal of the filter housing to deform causing the tightness. A heavy duty strap wrench with 1/2" drive socket break-over handle solved the problem.
   / Factory engine oil filter like it was welded on #19
Another tip is to take a razor knife around the perimeter where the oil filter is painted tight to the filter flange. When I did the 50 hr service, I mangled the oil filter big time, still could not get it off. I cut a couple of times around it with the knife, and it came right off.
   / Factory engine oil filter like it was welded on #20
I have had the luxury of 2 new tractors. Both had the same problems as you describe. Have the same problem with a lot of fasteners. Seems they are right at the spec limit for their size and condition. I have half a dozen or so filter wrenches and some times it takes trying several of them to find what will get one off. On the bolts and nuts, I'm up to 6 impact tools (and sockets) now, one for every peculiarity....thank you HF.
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
Eager Beaver 20XPT (A47477)
Eager Beaver 20XPT...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55218)
2017 RAM 5500...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
