Factory engine oil filter like it was welded on
   / Factory engine oil filter like it was welded on #1
thadri
Kubota bx23s
In the process of a 50 hour service oil change, drained oil and I can遞 get the factory oil filter off!! Tried a filter socket already, letting some PB catalyst soak in overnight, but seriously it逞エ like it was welded on in the factory!!! Help!!
   / Factory engine oil filter like it was welded on #2
They are on good and tight sometimes , you turning it the correct way ...
Been trying to turn counter clockwise assuming that is correct
   / Factory engine oil filter like it was welded on #4
YES...
   / Factory engine oil filter like it was welded on #5
Do you have a regular filter wrench also try both at the same time
   / Factory engine oil filter like it was welded on #6
Sometimes a big pair of channelocks, is the only thing, cause it will bite without destroying the filter. But there is the large screwdriver through the middle that should work.
   / Factory engine oil filter like it was welded on #7
I had the same problem on my Kubota- ended up using a BIG pipe wrench - worked great. Came right off. I BENT 1 filter wrench and broke a 2nd one before moving to the pipe wrench.
Good luck
   / Factory engine oil filter like it was welded on #8
Of course new filter smear a little oil on gasket. Factory sounds like they didn't do that.
   / Factory engine oil filter like it was welded on #9
You Kando anything with a pipe wrench! Sometimes a long pipe on handle! tapatalk_1559050859006.jpg
   / Factory engine oil filter like it was welded on #10
PB is for rust/corrositon. I've seen the stuff swell o-rings. Maybe you'll get lucky and it will turn the rubber gasket to mush instead of swelling it up and making it worst!
2007 John Deere 624J Wheel Loader (A54865)
2007 John Deere...
2007 FORD F-250XL SUPER DUTY TRUCK (A54756)
2007 FORD F-250XL...
2017 Kia Sorento SUV (A55758)
2017 Kia Sorento...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A53424)
2001 Club Car DS 6...
