F350 vs competition
/ F350 vs competition
Do they have the video to show how much faster it is to lift the cab off to rebuild the engine compared to opening the GM and Ram hoods, LOL!!!
I saw the cab and front end off many GM trucks also, my 05 being one of them.
Chris
/ F350 vs competition #43
I looked up the labor to R&I the engine for 2012 1 tons 4WD desiel automatic trucks, everything equal.
F-350 w/ cab removal 13.5hrs w/o cab removal 14.7hrs
Sivlerado 3500 17.1hrs.
Ram 3500 16.4hrs
/ F350 vs competition #44
Yea, its back and forth. The Ford just barely trumps the Dodge but smoked the Dmax.
I will be in the market next year for a new diesel if my job situation is stable. Yesterday if I were to buy it would have been Dodge with a Asain but today its Ford after watching that.
Chris
You changed your mind? I thought you probably weren't going to buy another diesel?
Not to be a smarta$$ but it takes more than one video to make me choose a manufacturer. To me there is a lot more to a $60k investment than just being 21 seconds faster up a 7 mile hill climb that I would not very often see. I am not saying one truck is better than the other, just that a manufacturer-published video is not enough to sway me one way or the other, especially since you would have to get the 4.30 rearend to even have the advantage.
The only thing my diesel trucks do is move big loads. They never move with less than 12,000# behind them.
I was convinced a few months back that a large gasser could do what I need but now not so much.
Like I said, it all will come down to job stability.
Chris
/ F350 vs competition #47
Did you hear that ford is coming out with a heated tailgate. Yup... They are doing this so your hands don't get cold when you are pushing it. Lol
Obviously to be used interchangeably, however its very funny. I remember back in the day them saying this about bumpers. It brought me back .... Lol
Interesting point on old 550 vs new 350....
/ F350 vs competition #48
That old F550 has much heavier axles, wheels/tires, frame and likely brakes.
/ F350 vs competition #49
Chris
In that case I guess a diesel is probably justified. :d
/ F350 vs competition #50
I keep hearing people say the half tons today are more truck than a 3/4 ten years ago. I don't buy it. I think the ratings may be getting close due to the engine/transmission advancements, but there's a lot more to it than power.
/ F350 vs competition #51
Until 1/2t trucks come with heavier springs and 8 lug, full floating axles they will not be as tough as 3/4t trucks from whenever.
They have the power, brakes, and transmissions now to pull whatever.
/ F350 vs competition #52
My brother has a fleet of 8 trucks mixed with '10 and newer Ford 450s & 550s and Dodge 3500, 4500 and 5500. They pull close to the truck's rated capacities daily and none stand up. They have all had major mechanical failures prior to 70k miles.
While these trucks are marketed to work hard everyday their drive lines cannot take it, regardless of Dodge or Ford.
As for Chevy, he will not buy Chevy as the do not over a cab and chassis nor a 4500/5500.
/ F350 vs competition #53
I agree Peacock. My stepson-in-law has a 2011 GMC 1/2 ton crew cab short bed 4wd. But whenever he wants to pull anything, he comes and gets my 2003 crew cab short bed 2500 HD with Duramax.
Ok, so that is only 8 years difference, not 10. But there is really no comparison between the two for towing capability. The ratings (HP and Towing) might be close, but you feel a whole lot more secure with the bigger axles, heavier frame, suspension, etc.
That's my opinion anyway......
/ F350 vs competition #54
Obviously to be used interchangeably, however its very funny. I remember back in the day them saying this about bumpers. It brought me back .... Lol Interesting point on old 550 vs new 350....
Yes I actually owned fords. Worked out as good as anything else. One thing I will say is diesel Cummings or anything else has troubles with fuel injections and it cost a wack of money to fix.
I usually owned newer vehicles but Right now I am driving a 1978 one ton crew cab, 454 Holley carb. Hard on fuel but this thing hauled a lot of stuff for the previous owner and some for me and it cost me the least to run. No payments, and nothing that cannot be fix fixed by a back yard guy, parts are cheep.
/ F350 vs competition #55
I believe my 01 f250 would handle loads much better than my 78 f250. Even if it was like new. As for working on them in a driveway... both are simple, but require different knowledge.
/ F350 vs competition #56
I like Ford, how much do you think a moderately decked out 2015 dually in good condition w 100K miles will cost in 2025?
When maybe I could afford it :)
/ F350 vs competition #57
probably more than a new one does now. :laughing:
/ F350 vs competition #59
$33,000
/ F350 vs competition #60
Its the same hill and the same weight. I agree though. They probably figured out it perfoms better at high altitudes vs the competition. Chris
The big question I have is did the ram have the 68rfe or the Aisin in the test? The Aisin has an advantage for pulling I bet ford used the 68rfe equipped ram. Plus the Aisin equipped ram has 50 ftlbs more torque.
The Aisin has the following gears
1st 3.750
2nd 2.000
3rd 1.340
4th 1.000
5th .770
6th .630
The 68rfe has
1st 3.23
2nd 1.84
3rd 1.41
4th 1.00
5th .82
6th .63
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
Frontier Hay Spear (A64126)
Frontier Hay Spear...
John Deere 1025R (A62177)
John Deere 1025R...
NEW CAST IRON FARM BELL KIT (A64281)
NEW CAST IRON FARM...
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
2022 EZ-GO ELITE...
