F350 vs competition
/ F350 vs competition #61
The big question I have is did the ram have the 68rfe or the Aisin in the test? The Aisin has an advantage for pulling I bet ford used the 68rfe equipped ram. Plus the Aisin equipped ram has 50 ftlbs more torque.
The Aisin has the following gears
1st 3.750
2nd 2.000
3rd 1.340
4th 1.000
5th .770
6th .630
The 68rfe has
1st 3.23
2nd 1.84
3rd 1.41
4th 1.00
5th .82
6th .63
Read this post from Mike Levine (mikeputc), who works for Ford (formerly ran pickuptrucks.com): Video: Super Duty vs Chevy, Dodge, I mean Ram - Ford Motor Company Discussion Forum - Blue Oval Forums
We went with the most capable / highest rated towing package from each manufacturer, which determined the axle ratios.
/ F350 vs competition #62
There is no way around it, the better gears will help the Ford no matter how the transmission is geared. Like so many others have said the results were stacked against the Ram and Chevy before the test was even started.
/ F350 vs competition #63
Bottom line, though, is that is the best that each company has to offer. Doesn't matter how the deck was stacked, Ford picked the best from each. What, should Ford use lower (numerically) gears just because the others don't offer the higher (numerically) gears? No, Ford should grab the best of the bunch from each, and show the results. It was stacked in Ford's favor because Ford offers something the others don't. Pretty simple.
/ F350 vs competition #64
I still put no stock in a test done by an OEM.
Let an independent 3rd party do the testing.
/ F350 vs competition #65
I'll give you that, and I agree with you.
But, let's not say that Ford stacked it against the competition. The only way they did that was by offering higher (numerically) gears, and it had nothing to do with this test. Now, if Ford would have used the F450, then yes, that would have been stacking it against the competition.
Not true. Look at the 1/2 ton test posted here a month ago. The Ford with 3.73 gears out performed the Dodge with 4.11 and Toyota with 4.30.
Tire size, gear ratio, tranny gears, and torqu range all factor into it.
Chris
/ F350 vs competition #67
I don't put too much stock in even a 3RD party test. You have to look at all of them with a open mind.
Sent from my Samsung SPH-L710 using TractorByNet
/ F350 vs competition #68
Chris
Come on, that doesn't count. The results of that test aren't in favor of the naysayers, so it gets thrown out! :duh:
/ F350 vs competition #69
Yup! Bottom line, they are all great vehicles. Drive them all and buy the one that fits your needs and wants the best. Who cares what anyone else thinks!
/ F350 vs competition #70
I get what you are saying....
Don't remember anyone complaining about that one
/ F350 vs competition #71
So we all agree, for the most part that rearend makes a difference- all other things being equal? And it is great of Ford to offer that for those that need it, but how many are actually going to opt for that, and how practical is it for daily driving? My guess is that most won't have it, yet everyone that owns a Ford diesel is going to brag about this video when in reality they could have a lesser performing truck (theoretically) if they had say the 3.73. This reminds me of a towing test I read a while back where they compared gas engines, and since Ford was the only one offering a v-10 at the time, guess who won. Iirc, they had the smallest, least powerful v-8 at that time.
I can see where a numerically higher rear axle *might* provide an advantage in a short sprint. It's much more difficult over multi-mile runs like we did at Davis Dam and in Colorado.
I also disagree with this... it may be true on flat land, but on a constant climb?
/ F350 vs competition #72
With a modern 6+ speed transmission, once you are out of first or second gear, rear end ratio is not relevant until you start hitting the rev limiter.
Aaron Z
/ F350 vs competition #73
With a modern 6+ speed transmission, once you are out of first or second gear, rear end ratio is not relevant until you start hitting the rev limiter. Aaron Z
I didn't say that.
Rear axle ratio is still relevant. Final gear ratio is what matters.
/ F350 vs competition #74
To me final rear axle gears make or break a truck, the newer trucks I have drove with 6 speed trannies and higher geared rear ends suck! Any of them, I have a load on my truck all the time, rather large road box, gas powered air compressor, and a box with chain, straps, chainsaw, gas and oil, I think you guys get the picture. Then the truck is beat on gravel roads and field roads 90 percent of the time, my o8 Chevy had been a good truck, it has right at a 100000 miles on the clock, bit it is not built heavy enough for this kind of use, mine will probly be 3/4 or 1 ton next time. The only half ton I have looked at built heavy enough in the rear end was the Toyota crew max, no other on on the market in my opinion is that heavy, if you drive them on the highway towing, there probly ok, but for farm use, I just don't think I will have another 1/2 ton! LUTT
/ F350 vs competition #75
No mention of fuel used in the "test"??????
It fits that they use Mike Roe for the spokesman, I guess it's just another "Dirty Job" for him.
/ F350 vs competition #76
/ F350 vs competition #77
I guess you just gotta buy a Ford, you never want to get caught underpowered !
/ F350 vs competition #78
Naw, the best looking are '41, '64, and '32 in that order. And maybe the '89. :D
Good choices on the 41, 64 and 32. I would leave off the 89 and add the 53 to 56 generation. So cool.
/ F350 vs competition #79
Tell that to all my Powerstrokes that keep trying to bankrupt me, LOL.
But to be fair had my share of front end problems with Ram's. Haven't tried a GM yet.
/ F350 vs competition #80
I agree with this to a certain point. I liken the final drive ratio to a multi-speed bicycle. The transmission being the cogs on the crank and the rear end being the cogs on the wheel. The cog on the wheel has just on gear whereas the crank has multiples. Once out of first gear, the transmission will choose the proper ratio based on the program the engineers established for best performance. First gear and the final gear are the only limiting gears.
The only variable is weather the transmission frictional losses are equivalent to the rear ends losses.
My friend has the same configuration of truck as me but with a higher axle ratio. My truck will shift into 6th gear at 35 mph whereas his won't until 40. I joke with him and tell him I get better mileage in town.
2007 Toyota Tundra 4x4 Ext. Cab Pickup Truck (A64556)
2007 Toyota Tundra...
1996 Polar DOT 407 8,500 Gallon Single Comp Insulated T/A Diesel Tanker Trailer (A64194)
1996 Polar DOT 407...
213091 (A64276)
213091 (A64276)
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67148)
2012 INTERNATIONAL...
