F Series vs. ZD
   / F Series vs. ZD #91
The newer mechanical suspension seats are pretty good & way better than the older ones.
I’d try one first.
Adding an air ride seat assy shouldn’t be too bad of an install but you’d need to run power to the pump motor.
   / F Series vs. ZD #92
I love my ZD1211-60 but my shoulders do not! Just got a F2690-60 with hopes the steering wheel gives me the relief needed to mow 20+ acres each week
   / F Series vs. ZD #93
Keep us posted.
I mow around 9hrs a week on my ZD15/1611-72
I tried the F series but hated it on my steep banks mowing horizontally so I flushed it.
   / F Series vs. ZD #94
My ZD1211 72 (sold) Bogged pretty bad in thick grass but again I have steep hills & banks here I mow.
It was absolutely fine on flat ground mowing weekly growth.
I don’t like a mower, tractor or truck that bogs lol
The extra $$ for more power is absolutely worth it to me.
The ZD1511 emissions is Fine as long as they have the newer calibration in them & the newer ZD1611 is Fine too.
No problems on either one here mowing 20+ acres a week on my farm.
Way better mower than JD Scag or Ferris imho.
I just wished they offered a 84” deck.
You don’t want a RD deck especially if your grass is thick and / or tall : it’ll windRow TERRIBLY.
They cut exactly the same but clippings dispersal is knocked down by the wide tires & the radiator will suck dry clippings up & run hot every 2hrs.
Don’t buy one imo
Correct. exact thing happened to me. I purchased a brand new ZD 1211 RD and during my first use it overheated - alarms and lights...I mowed for about 4 hours and it overheated about every hour. dry grass just gets thrown right on radiator - took it back for an F3710 - mowing field type stuff...
   / F Series vs. ZD #95
I mow all kinds of dry/chaffy field stuff and have loaded my rad, but mine don’t overheat.
   / F Series vs. ZD #96
The side discharges will also buildup chaff on the radiator, but apparently much less than the rear discharge. If I skip a day blowing out the radiator I notice the coolant gauge rise a bar or two.
I guess there are a variety of grass types / conditions involved, but any rear discharge mower that I have tried left a windrow mess.
   / F Series vs. ZD #97
I bought a used JD 1435 diesel front mower side discharge 7-iron at a local Metro Parks auction $2500. Yanmar motor. Starts on the 2 revolution even after sitting for a few months. Found a 60" front rotary broom for it and I will NEVER use or need a snowblower, plow or pusher again, and I've tried all 3 before getting a broom. The driveway is spotless after brooming snow and is dry in 1 hr. I can spray the snow even from 10" drifts as far out as I want or need to using rpm. And it does all this at 15 (measured) mph. The motor isn't even warmed up when I'm done.
As and added bonus, I bought a 3:1 gearbox with a 540 pto stub on it and can run my 45kW Winpower PTO genny off of it. The 1435 is about 22hp so its 11kw potential is plenty of electric power for us. I also still have my F935 earlier version of the 1435. It can also run the genny and a 76" rear discharge deck for chomping thru high field grass, weeds, trees, woodchucks, and whatever it chooses to munch on.
   / F Series vs. ZD #98
interesting...i claimed something was defective with it...it was brand new and overheated every hour. the dealer took it back and I got something else. I was surprised with the issues, I have a Kubota RTV and it's been problem free for 15 years.
   / F Series vs. ZD #99
I overheated my ZD-331 mowing similar tall, dry chaffy stuff once, but I attribute that more to the radiator being older and probably having accumulated more grit/dirt for many years.
The 1211’s will accumulate chaff, but the rad seems to be plenty big to handle it.
Gotta keep those bonnets sealed up tight.
   / F Series vs. ZD #100
interesting...i claimed something was defective with it...it was brand new and overheated every hour …
Normal characteristics of RD deck. Nothing defective.
My old one was the same way.
Both of my SD will run hot too if dry & wind is blowing clippings back on you & the mower (I can’t run a side chute with my heavy clippings around the farm)
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
Yanmar YT359 (A53317)
