F Series vs. ZD
   / F Series vs. ZD #141
It just sets right in with no clamps or bolting. With even just 2 psi it is a snug fit between the seat and the bottom of the base. And 11-12 psi is were I usually keep it.
I'm afraid that just won't do! There must be a complicated retaining mechanism to hold that thing!
   / F Series vs. ZD #142
   / F Series vs. ZD #143
Update. Ended up keeping the ZD1211-60 bought F 2690-60 working on air pressures on the F to get rid of the excessive bouncing. Each machine has pros and con's. Just lucky that I can keep both and every once and a while can use the old BX2360 for the really rough stuff šŸ˜‰
   / F Series vs. ZD #144
Update. Ended up keeping the ZD1211-60 bought F 2690-60 ... Each machine has pros and con's …
Does the F spin the inside tire doing fairly tight turns ?
My F3710 i got rid of was Horrible when going up slight hill turning :mad:
   / F Series vs. ZD #145
My F2000 does unless I engage the 4wd.
   / F Series vs. ZD #146
4wd seemed to make my F3710 spin worse.
I even fluid filled all 4 tires & it didn’t help.
The F just didn’t suit my application at all so I traded it for a ZD1611.
404 (A52706)
404 (A52706)
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
Suzuki Eiger 400 Quadrunner Four Wheeler (A57453)
Suzuki Eiger 400...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Tractor Tires and Rims (A56860)
Tractor Tires and...
7ft Fork Extensions (A56860)
7ft Fork...
