Exposed pistons
/ Exposed pistons #1
Skidmark25
North Shore, MA
B7610
No, this isn't that kind of post. Get your mind out of the gutter.
I have a Woods BH6500 that I leave on in the winter when I am pushing snow around. Always backing into snow banks and getting the hyd. pistons wet.
I have read somewhere, sometime ago that there is a protective coating / film to spray on the exposed part of the hyd. piston to keep from rusting / oxidizing when not in use for a while.
Any comments???
/ Exposed pistons #2
Putting some type of protective coating on piston rods is a good idea. All my equipment is under protective cover (roof). But the piston rod on my grapple had rust marks on it last spring when I got it out of storage.
Thanks for the reminder. I'm on my way out the door to coat all the piston rods on my attachments. /forums/images/graemlins/grin.gif
/ Exposed pistons #3
Coating with oil, or a light coating of grease works well.
Probably best to wipe it down well before next use to kept it from grimming up. Surface rust can be removed. Heavier rust can cut seals causing leaks.
I'd be leary of spraying with harsher stuff to avoid seal damage.
Ron
/ Exposed pistons #5
I use Liquid Wrench Super Lubricant & Penetrant. There are other products. But thats what I have. If you are storing outside you may want to put grease on the rods.
/ Exposed pistons #6
</font><font color="blue" class="small">( I have read somewhere, sometime ago that there is a protective coating / film to spray on the exposed part of the hyd. piston to keep from rusting / oxidizing when not in use for a while.
)</font>
Yep, axle grease.. cheap axle grease...
I just dip a small handfull out.. then run over my loader pistons when i let it set.
Also.. If I do any painting.. I greasy my pistons to keep them from getting paint on them.. My hyds guy hats to see systems contaminated with lifted paint.
Soundguy
/ Exposed pistons #7
Grease in a paste form works well when applied on a dry surface.
Ronald
Ranch Hand Supply
/ Exposed pistons #9
The dealer I bought my Schaeff of recommended..
1) Articulate all joint back and forth weekly to get a nice film of hydraulic oil on them and for the seals to remove dust etc.
2)If space allows...put the boom,dipper and curl into such a position that all rams are fully home.
(although I do put grease on the boom ram as its on top and extends when a pack the other two)..
Rob
/ Exposed pistons #10
Guys, we all missed the most obvious............
Move all the rams so the piston is INSIDE the ram. On some equipment, that makes you hook a tractor to it to move it.
But in some cases, it makes theft by towing it off harder.
G'day!
ron
/ Exposed pistons #11
</font><font color="blue" class="small">( Guys, we all missed the most obvious............
)</font>
I thought I'd covered that one..
Rob
/ Exposed pistons #12
Move all the rams so the piston is INSIDE the ram )</font>
Not missed.. just not always possible. On my tractor with a fel, if I want the bucket flat on the ground, and not have the toothbar jutting up a foot in the air, i have a top cyl partially exposed. Also.. power steering rams. Some of them are a double headed piston always having 1 side exposed...
Soundguy
Vacuum Tank (A61573)
8in Channel Tooth Bucket Mini Excavator Attachment (A61572)
8in Channel Tooth...
STEEL DECK TRAILER DOVE TAIL, FLOATER AXLES, (A63291)
STEEL DECK TRAILER...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
