How long can cylinder rods remain exposed to the elements before they should be coated with something?
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #11
Not everyone has the option to store things inside.
My long term storage is under my solar panel array. That's where my blower will sit until the next winter season and where my FEL will sit a lot unless I have a use for it. While not inside it is semi protected from the worst of things and blocks direct sun during the hottest part of the day but it's not really "inside". I could probably store the blower inside, but I'll have a lot more room in my shed if I don't but I really don't have anywhere except outside to take of the FEL when I don't need it.
I always follow these types of topics with interest to see what others do. I was thinking of putting a good coating of grease, fluid film or chain wax on things I want to protect and then checking regularly and reapplying as needed.
Store it inside!
No "extended storage" issues!
Whish it was that easy :) It was already a hard sell to my wife to buy the tractor, adding a shelter to it, not going to happen anytime soon lol
Everything you are concerned about is legitimate.
The issue is the quality of the chrome coating on the cylinder rod or rods. Dont count on it being a high quality chrome coating.
You can safely use grease or fluid film on the rods and tie news print to the exposed rods as an added measure.
The rod wipers in the packing glands are only as good as the chrome coating on the cylinder rod so keep that in mind when you have a lot of dust to deal with as it should be washed off it if at all possible when you are done digging.
You can always use Cosmolene and a Cosmoline stripper to protect the exposed portion of the cylinder rods. The issue is that the Cosmolene MUST to be stripped before the back hoe is used as the rod wiper would be damaged from the Cosmoline. I always used DL hand cleaner to break up the Cosmoline coating.
It would be simpler and cost less to coat the cylinder rods with brushed on fluid film and wrap them with newsprint using nylon twine to hold the newsprint tight to the cylinder rods.
If you use grease you have to be sure to clean the rods well to prevent any fine dust from getting pulled into the rod wiper.
Fluid Flm
Saran Wrap
4 or 5 wraps of newsprint you can also coat the newsprint with Fluid Film and then wrap it which lets it soak into the news print.
nylon twine tied in a spiral wrap using square knots
It is stored safely and the everything is easy to remove using a leatherman tool or the scissors on the Leatherman tool
Leon
Hmm, didn't think about using Saran wrap. That could be an easy solution. Wipe de rod to remove any contaminant, coat with hydraulic fluid, wrap the rod in Saran wrap. Then when ready to use again, unwrap. The fluid should still be clean and being the same stuff that's INSIDE the cylinder, shouldn't require anything else, right?
I believe those rods are stainless steel so they won’t rust very easily
Probably, but I prefer being safe than sorry :)
I greased my cylinder rods when I took my loader off. To clean the grease, you can wrap twine around the rod, then pull to the other end. It will then be free of grime.
That seems easy, thanks :)
My blower is currently under a tarp. The same tarp what will be used to cover the backhoe once I swap them. I also put a tarp over the inside of the tractor, to cover the seat (seats when the backhoe is there), levers and dash. Thinking of adding something to cover the tires as well since the sun can be hard on them.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #14
Yes, quality of rod is paramount to resistance to corrosion.
SALT, manure and other chemicals has to be the worst.
Looking at a cylinder, one has this notion that it is naked steel and has to be protected. It already is. Probably, far better than any other piece of your machine in fact.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #15
Fluid Flm
Saran Wrap
Leon
You ever leave newsprint out in the weather for a month or so? Why would any reasonably intelligent human think that would be effective?
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #16
My 2004 B21 has never been under cover and I never put grease or whatever on the cyl rods. Coastal environment. The rods are as bright and shiny as the day I bought it.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #17
Does anyone wax their rods?
Old-timer told me they put a coat of wax end of season on exposed surfaces.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #18
Worrying about a cylinder rod rusting out here in the West is non existent.
If they were rusting, the high priced machine sets too much. Better off renting at that point.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #19
Been out here 40+ years now. Never seen any rusting or pitting of any cylinder rods. All my implements, with hydraulics, including my tractor, are stored in carport stalls. One thing I've noticed. Being stored under cover in the carport stalls - nothing ever gets moisture forming on the cold steel. All my cylinder rods are sucked up when implements or tractor are put away.
Our humidity here is always very low. Unless it's raining and we don't get a lot of that.
I do put a very thick coating of grease on the four cutter blades on my Wallenstein chipper. It just makes me feel better to do that.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #20
If you protect your tractor from deterioration by weather, you are simply protecting your expensive investment!
Would your wife be OK with leaving the roof of your house to leak ..... all Winter....in Quebec?
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
2014 Gravely 60" Zero Turn mower (A55973)
2014 Gravely 60"...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2023 John Deere 333G for Parts (A55315)
2023 John Deere...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
