Mowing exhaust pipe discharge
/ exhaust pipe discharge #1
case580c
Northern California
Kubota M5140 Case 580C, Case 450C, Case 850B John Deere 350C, Kubota L185, Kubota L245H,
I am shopping for a new tractor looking at the Kubota L series noticed the exhaust pipe discharge is low near front axle. (I am use to the exhaust pipes coming up through the hood.) I am concerned about starting a fire in tall grass with it's location. especially with the new tier 4 system. This was on an L3901. Would appreciate you thoughts and experiance Thanks
/ exhaust pipe discharge #2
You can fit a 'Spark Arrestor' or you can fit an 'Upswept Exhaust' Kit.
:wrench:
/ exhaust pipe discharge #3
Never heard of a diesel engine exhaust starting a fire. That's one reason I like my diesels. I can go though the worst of things and not worry about it; haying especially where the crop is ripe for the plucking...never a problem in 30+ years of haying. My 2000D exhaust is bent down at the tip which is behind the rear axle. The 2400 exhausts straight out too.
/ exhaust pipe discharge #4
My Grand L3560 exhaust is on the drivers left along the side of the motor down low. It's coved with a vented heat shield to help prevent contact issues. Spark wise i am with texasmark on thinking the diesel exhaust is likely to be a fire problem.
/ exhaust pipe discharge #5
The L's I looked at have the venturi type cover on the exhaust tip to help draw in outside air and reduce the exhaust temp at the outlet, like you would see on a Ford or Chevy diesel with a dpf.
Spark arrester would also help.
I haven't seen reports of dpf tractors causing fires. Doesn't mean it hasn't happened, just haven't seen it brought up.
/ exhaust pipe discharge #6
I have L2800 side exhaust yet to have problem mowing hay etc.I don't leave the tractor running should I stop either while mowing.
Heaven Hill Burbon Barrel (A65583)
Heaven Hill Burbon...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
1997 International 3800 School Bus (A64194)
1997 International...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
(3) Pieces of Poly Pipe (A62679)
(3) Pieces of Poly...
