Exhaust Mod on my 3725
   / Exhaust Mod on my 3725
Eddie,
To answer your question, "it fit" the space I had available. I needed a short, fat muffler. This was attempt #3, as the first one was too small in the body, exhaust guy thought I needed bigger chamber, so I looked at an IH-6, but the inlet and outlet pipes were too big around, this IH-4 was "just right". Met the size for volume and for length that we were looking for.
   / Exhaust Mod on my 3725 #52
I have to run my 4520R at an idle for a few hours at a time while I spray Iron in our fruit groves and the dpf light is on.
Does anyone have a picture of the dpf gut removal from their machine?
I really need to remove this soon, the machine has 71 hrs on it
Thanks Ernie
   / Exhaust Mod on my 3725 #53
With a 2020-2021 3620 you loose the dash temp and tach function. I was doing some work on it and started the engine without the data logger and cat-dpf plugged in. Wiring must have changed in the newer models.
   / Exhaust Mod on my 3725 #54
On my 4720ch, when I lost my tach it was because the alternator failed. What it does is count the ac waves generated and converts it to engine rpm by multiplying it times the gear ratio of the engine to the alternator. Not sure if yours is the same.
   / Exhaust Mod on my 3725 #55
Wondering if they started combining the wiring harness for the engine and the DPF on the same plug.
   / Exhaust Mod on my 3725 #56
Alternator is fine. Plugged everything back in and gauges work normal after realizing I had forgot to do so.
Thanks for the heads up abranz, that is some important information we'll have to let folks know.
Now the trick is going to be if someone with the later wiring harness can figure out the pinout to wire in a bypass.
   / Exhaust Mod on my 3725 #58
That is interesting. Maybe it will be simple to figure out once the wiring diagram is released. But one could just leave the data logger plugged in and ignore the light.
Is it only the data logger plug that needs reconnected abranz? Or is it more of the harness that connects the sensors to the DPF cannister?
Because yeah, if it's only the data logger plug, that won't hurt anything, but the dpf light will stay lit on the dash.
   / Exhaust Mod on my 3725 #60
I’m not sure. The data logger and dpf sensors were all disconnected until I realized my mistake.
UNUSED FUTURE SZYMJ HYD MINI SIDE SWING STUM GRIND (A58376)
UNUSED FUTURE...
Eager Beaver 20XPT (A55272)
Eager Beaver 20XPT...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
2018 John Deere X350 (A57149)
2018 John Deere...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
Chevrolet 2500 Flat bed (A56436)
Chevrolet 2500...
