Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #381
Hey fellas,
Any problem using these forks on my 5740? I like the lighter weight, but the manual says only up to 40hp.
Bradco Compact Tractor Loader Pallet Forks, Model Universal Skid Steer Quick Attach
Thanks..
Those would be just fine, as long as you use them sensibly and don't exceed the rated lift capacity of 2,300 pounds. If you want to be rougher, we haven't had a single issue with our HD pallet forks.
All of our forks will ship free to a commercial business or supporting freight terminal within 1,000 miles of Newton, NC.
Travis
/ Everything Attachments #382
PRF,
I bought the Bradco Compact set from EA. My tractor is 50hp. But my FEL capacity is 2000lbs. So I figured they were just about right for me. They work great. I recommend a light coat of grease on the rails and on the fork pins. They're heavy duty enough. It's not like I'm going to be ramming them into bank vaults.
xtn
/ Everything Attachments #383
I was torn between these and the heavier duty forks for my l5460 and went with these because I decided I wanted a lightweight fork with 48 inch tines and this seemed the best choice.
Still a little torn if maybe I should have gone with a heavier duty incase I get rambuncious moving logs or something......
My owners manual suggested a fork with a 3000lb capacity if I recall. I'll just be conservative with them.
/ Everything Attachments #384
Thanks all.. Sent you a message Ted. I would only lift pallets now and then.. I have a grapple for the rough stuff :)
/ Everything Attachments #387
Wanted to give a quick "Thank you" to Travis and the folks at EA My tooth bar came yesterday. Good price, friendly quick service, fit like a glove.
/ Everything Attachments #388
I was wondering if you have heard of any way to mount a smaller mid mount mower on a LS J2030H it comes with a factory set up for a 60" deck and a I have a customer who would like a 50 to 54 inch deck.
/ Everything Attachments #390
If LS doesn't offer a smaller mid mount mower, I don't think it would be possible to put a smaller one on the tractor. It would be best to ask that question in the LS tractor section of TBN.
Sorry I can't help.
Travis
/ Everything Attachments #391
Travis , Ted : Sent a email regarding Your Deluxe Value Scrape Blade V2.0 7' model and shipping costs to my location although as in email , it would likely be easier and possibly cheaper for me to pick at at one of the many freight companies that have terminals here in this area .
No rush , when ever you have time .
Thank You ,
Fred H.
/ Everything Attachments #392
Thank You ,
Fred H.
PM Sent
/ Everything Attachments #393
Thank You !! :) . Although I can get other blades around here , in looking at your pictures and spec's , For the price and shipping , Your Blade would far exceed any that other dealers here carry .
Again , Super Thanks and Happy Holidays .
Fred H.
/ Everything Attachments #394
Fred H.
No problem Fred. We don't call them Value Blades for nothing!
Tilt
Angle
Offset
Quick Hitch Compatible
Built in Stand
US Made cutting edges
Merry Christmas to you!!
Travis
/ Everything Attachments #395
Hi Ted,
I'm going to be ordering a post hole digger for my 3520 (deere), and wanted to confirm the 6900 HD was the correct size.
Also, I'm in NC like you, and plan to use this to make planting trees and shrubs easier. We have decent soil on the property, and I'm wondering if I should go with a 12" auger to be more useful on shrubs and small trees, or the 18". I figure I have to soften the sides no matter what given our clay content in the piedmont, and 3 x 12" holds in a triangle could make a decent hold for up to a 1.5" tree.
What do you think? 12" or 18"
Thanks,
Todd
/ Everything Attachments #396
Todd, yes the ETA 6900 HD post hole digger is a good match for your tractor. Rather than trying to join multiple holes, I would just use an 18". Our augers have replaceable corkscrew points and cutting teeth to help them dig.
If you have a large operation, a bucket mounted auger will enable you to apply down pressure.
Travis
/ Everything Attachments #397
It will likely drill/dig under 200 holes in the next 2-3 years. I don't think we need down pressure :)
Thanks,
Todd
/ Everything Attachments #399
It is quite possible that the wife in this tragic story was trying to put down pressure on the digger. I am a fan of hydraulic diggers, no PTO shaft. Be safe whatever you do
Post Hole Digger Death
Thanks.
Nobody will go near it when it is on. We'll operate it from the seat.
Ted,
Given some people have tried to apply down pressure from behind the tractor, have you considered welding a pipe fitting to that flat plate at the end of the boom, where the gear box hangs down. Then people could screw in an 8' length of pipe and apply down pressure from far away from the auger. I am confident we won't need that on our property.
Todd
Never mind, just read the post on the auger possibly grabbing fence stuff below ground level and pulling a person in. scary stuff!
/ Everything Attachments #400
Bought the everything attachment subsoiler Tuesday evening got it Friday evening super fast shipping . Great beefy unit . Super great salesman for double check'n they had one and get it out to me .
Sent from my iPhone 5 using TractorByNet
Status
2015 Freightliner (A64119)
2015 Freightliner...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2013 FORD F-150 (INOPERABLE) (A67714)
2013 FORD F-150...
Trek (A65640)
Trek (A65640)
2008 X534 AWS For Sale
2009 FREIGHTLINER M2 Slick Line (A67714)
2009 FREIGHTLINER...
