JasperFrank
Elite Member
- Joined
- Nov 23, 2018
- Messages
- 3,089
- Tractor
- Ford 1220
Why, exactly do we hate moles?
They undermined my above ground pool, popped the liner, and sent 12,500 gallons of water through my garage.Why, exactly do we hate moles?
www.jteaton.com
This is what I use and the minefield I bought into with home purchase is no more.I don’t know about moles, but this works well for gophers.
Answer Pocket Gopher Control – 16oz Rodenticide Bait for Pocket Gophers - J.T. Eaton
Effectively eliminate pocket gophers with JT Eaton 276 Answer Bait. Moisture-resistant, diphacinone-based formula targets gophers deep in burrows for lasting garden and lawn protection.www.jteaton.com
I have had a lot of ground squirrels the past few years. After live trapping and removing almost 20, I decided to get tough and now use Eaton’s Answer. They can cause a lot of damage.This is what I use and the minefield I bought into with home purchase is no more.
Now it is simple... at first sighting of activity my answer is Answer.
The tree farm just got a Rodenator so more to follow.
That place was over run with in ground squirrels... worst ever seen.
Thanks CAD / 2-4-D would kill my st augustine grass...being in Va, you have a colder grade grass that les broad leaves. Im also looking into nematodes bc they kill grub larvae...someone mentioned, get rid of the grubs, and the moles will leave...Possibly, the same thing that got RID of a groundhog under my deck would work,,
I have NEVER seen this method mentioned.
The groundhog was happily living under the deck, coming out each evening, munching the grass for his evening meal.
Well, I decided his food did not need to be so appealing,,
I sprayed the grass with 2-4D,,
That did it, one application, he did not want to travel past the 2-4D for food, so he simply moved.
My concept was to get him further away from the deck, to give me time to take a shot.
No need to shoot, trap,, anything,,
He just left,,,
I could imagine the same thing could work for a mole,,
spray something that "treats" the lawn, but, the mole dislikes for some reason.
My application was a WIN-WIN !!
I got rid of the groundhog,, and the clover/broadleaf weeds were gone,, also.![]()
I believe that is pocket gophers.Mole hills are where moles push dirt up out of their tunnel, so the dirt sets off the trap as they push it up and trip it before the mole gets there.
I doubt moles would be a solution to anything.I wonder if moles might be the solution to the jumping worm invasion in my area?
Good luck! Let us know how it goes, please.Thank you guys, very good advice & suggestions. I’m going to do my research and come up with a plan…
JD, moles push up very small amts of dirt, but their main MO is raised or pushed up sod. Gophers are 100% mounds of dirt usually every 4-6ft. I have both gophers and moles. The gophers I easily control w Cinch traps. This thread will hopefully help me to find a permanent solution to eradicating these pests. If I do, I will certainly post my findings....thanksI believe that is pocket gophers.
You can get rid of all the grubs you want, but if you have earthworms, that's their primary food. You can spray all the weed killer you want, but moles eat meat. It won't change a thing. The only way to eliminate the mole's food source (worms and insect larvae) is to make your lawn a sterile growing medium for grass. And that means chemicals that kill every worm and insect. Trapping is still the best way. I don't care for poisoning animals.Thanks CAD / 2-4-D would kill my st augustine grass...being in Va, you have a colder grade grass that les broad leaves. Im also looking into nematodes bc they kill grub larvae...someone mentioned, get rid of the grubs, and the moles will leave...
