Oil & Fuel EPA Diesel Report
/ EPA Diesel Report #1
SimS
Rutledge, GA
Kubota L3710DT, Case 1845C, Takeuchi TB015
TBN'ers;
<A target="_blank" HREF=http://www.cnn.com/2002/HEALTH/09/04/diesel.exhaust.ap/index.html>http://www.cnn.com/2002/HEALTH/09/04/diesel.exhaust.ap/index.html</A>
I just ran across this article on CNN.com and I wanted to know if removing sulfer from diesel fuel would have any adverse effects on diesels engines not "designed" for no sulfer fuels?? And if they remove sulfer, will additives be able to replace sulfer's current properties in the fuel?
Thanx;
Sim
/ EPA Diesel Report #2
Sim,
Europe has operated low sulfur diesel for a number of years with no adverse effect that I am aware of. Also here is a link to dieselnet for more info on Kubota and their emission with the E-TVCS setup (used in most all Kubota CUT's)
<A target="_blank" HREF=http://www.dieselnet.com/kubota/>http://www.dieselnet.com/kubota/</A>
Carl
/ EPA Diesel Report #3
I remember seeing some news reports about Californias "clean" diesel. Truckers hate it, claiming major engine repairs. They all top off their tanks before entering the state.
/ EPA Diesel Report #4
I have no expertise in the fuel formulation area, but have read there is little or no difference between diesel and home heating oil. Seems to me that someone with oil heat and a compact tractor would be burning a lot more fuel in the furnace than the tractor.
1. Makes me wonder if there is any credible threat.
2. Howcome the CDC or AMA or someone medical didn't announce the health risks?
3. Are oil furnaces next?
Gotta run. It's lunch time and my broiled spotted owl is getting cold..............chim
/ EPA Diesel Report #6
<font color=blue>It's lunch time and my broiled spotted owl is getting cold</font color=blue>
Spotted owl should always be deep fried in animal based cooking oil. /w3tcompact/icons/laugh.gif
/ EPA Diesel Report #7
I always thought whale oil wuold be better.
/ EPA Diesel Report #8
Thanks for the cooking suggestions guys. I may try some lard. Ever since I heard the term "sperm whale" whale oil kinda turned me off though.................chim
/ EPA Diesel Report #9
I believe the main thing you get with higher-sulfur diesel is higher lubricity (can't remember if this is from the sulfer itself, of if the process that removes sulfur also removes some of the other goodies that help to lubricate). Most modern diesels are designed to run on low-sulfur fuel. I'm not sure how "no-sulfur" fuel will affect them. If you are concerned, or have problems there are additives you can buy to help (for example, I believe some of the anti-gel additives also have lubricity additives in them).
Another alternative is to use Bio-diesel (diesel fuel made from vegetable oil - in fact, it can be made from the left-over fryer oil from MacDonald's), it has much better lubricity than regular diesel (low or high sulfur), and as an added bonus, emissions are MUCH lower. There is also a blend of Bio-diesel and regular diesel known as B-20 (for 20% bio-diesel). This also has very good lubricity and has been approved by some tractor manufacturers. B-20 blend is REQUIRED in some european countries (probably for it's lower pollution properties and the fact that it ruduces their dependance on foreign oil)
One caveat of running straight bio-diesel: It cleans your engine and fuel tank. If you've been running petroleum based diesel for a long time, it will free up all the gunk in the bottom of your fuel tank and clog your fuel filter. (A lot of people making the switch in diesel cars & trucks are putting in a cheap pre-filter in an easily accessible place for the first few tanks to avoid clogging the main filter).
John Mc
/ EPA Diesel Report #10
John,
Sounds like a real win-win. You get a cleaner fuel system and smell like your cooking french fries. :)
/ EPA Diesel Report #11
</font><font color="blue" class="small">( I have no expertise in the fuel formulation area, but have read there is little or no difference between diesel and home heating oil. Seems to me that someone with oil heat and a compact tractor would be burning a lot more fuel in the furnace than the tractor. <br><br>1. Makes me wonder if there is any credible threat.<br><br>2. Howcome the CDC or AMA or someone medical didn't announce the health risks?<br><br>3. Are oil furnaces next?<br><br>Gotta run. It's lunch time and my broiled spotted owl is getting cold..............chim )</font>
From what I have read Diesel engines are cleaner burning than gasoline engines so why is the EPA going after them?
/ EPA Diesel Report #12
They have all ready screwed up the small gasoline engines to where you can't keep them running .
Seems their policy is make them emission free even though doing so will cause them to fail to run.
Maybe that's their ultimate goal -A non running motor equals zero pollution.
/ EPA Diesel Report #13
I've used no-sulfur diesel on occasion from Citgo in my old Benz with no troubles. They had it in the New Orleans area. It was clear and had no smell, like water.
Also, Mercedes has been making fuel injected gas engine cars since about the early to mid 50s. The injectors look like the ones in my 240D. It's possible to make mechanical pumps where the pump screws don't actually touch. Suspect that's what they do. However, I doubt there's nothing to that old wive's tale about lower sulfur lowering the lubricity of diesel fuel. I want to see actual research reports on it to believe it.
Synthetic oil has a little more lubricity (about 3% better fuel economy and about that in plus power from it) than dino motor oil. Synthetic oil has ZERO sulfur.
Ralph
/ EPA Diesel Report #14
We have had this stuff out here on the West coast longer than most places. Problems with lubricity and lower power. Lubricity issues come in the form of O ring failures in injectors and fuel pumps. Ends up with some high cost rebuilds. One friend with a 2000 Dodge truck lost his fuel pump at only 46,000 miles. The 20 MPG Dodge truck now is lucky to get 14. Think we may see this happen nationaly soon and us folks who operate older diesel equipment will need to make sure the proper lubricity additive is mixed with the fuel.
Chris
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2011 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2011 Caterpillar...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
1995 PONDEROSA 16' STOCK TRAILER (A64278)
1995 PONDEROSA 16'...
2014 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2014 Caterpillar...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
