Lubricity
/ Lubricity #42
Well I am still uncertain.
After following this thread with interest from the start I was ready to go out and buy additives.
Then when I did some research on some of the additives available on the local market it turned out all they contained was hydrocarbons, nothing better than snake oil. And these are top selling brands.
When you read the labels on the additive bottles they tell you nothing about what is inside.
More than one dealer I have spoken to said not to worry about using additives.
I would like to be convinced but the products that performed well in the research document that has been posted are not readily available where I live.
Neither is biodiesel.
/ Lubricity #43
My POV is this: if things were as bad as additive makers want us all to believe then NOTHING would be running the way it should, big rigs doing hundreds of thousands of miles, diesel backup generators for hospitals, you name it, it would all be seized up or broken down on the side of the road, field etc.
Studies are just that - studies. Graduate school taught me a number of things, one of the most important is follow the money in any research/study and one will find the underlying reason why the study was done.
Raw ULSD for the study makes sense for showing what the various additives could do if they were the ONLY thing being added to raw ULSD with no manufacturers additive package to contend with in the real world of fuel sold to consumers.
Seems to me the facts are: we as consumers are at the mercy of the fuel sellers and for that matter, the additive sellers.
In the real world it would be near impossible to do a study of the effects of each additive on say ten identical tractors, all doing the same work for a set number of hours etc., and then tear their engines down and see quantitative results that would be meaningful to us as to whether to use additives, and which ones, and in what quantity. Ten operators might get the same number of hours of work done but the results might still vary because of the human factor, the tolerances of each engine, defective parts, poorly set timing, injection pumps, etc.
So I say, go out and do your work/play etc. and use an additive if it gives you peace of mind, or subjective positive results for the $ it costs.
And don't forget to be on the lookout for shark bites, and meteors!:laughing:;)
/ Lubricity #44
I was out with a buddy last night in his 2004 Jetta TDI. He has 450000 km's on it and said he has never added anything to the fuel.
Snake oil or not, I use an additive. For the 50hours a year I will use my machine, the cost is less than $20 and it makes me feel good. :)
/ Lubricity #45
I agree. The study would have been better if it was larger and included real world fuel from a few different dealers at the point of sale after additive packages were included. If all fuels at the pump already have adequate lubricity then the after market additives are just frosting and more of a psychological boost than anything else. If however the additives do lower the wear numbers significantly while pump fuel is spotty then perhaps it is worth something.
I am most impressed by just plain old soy biodiesel. I wish they sold it in quarts so it would be easy to make up a 2% biofuel without storing larger amounts than would be likely to be used in a six month period.
/ Lubricity #46
Well said!:thumbsup:
But if there is a product that shows the "potential" of extending the life of equipment such as bio-diesel which is (in my area) inexpensive and(in all but winter months)available why not try it?
/ Lubricity
Quote: "Studies are just that - studies. Graduate school taught me a number of things, one of the most important is follow the money in any research/study and one will find the underlying reason why the study was done.
In the real world it would be near impossible to do a study of the effects of each additive on say ten identical tractors, all doing the same work for a set number of hours etc., and then tear their engines down and see quantitative results that would be meaningful to us as to whether to use additives, and which ones, and in what quantity. Ten operators might get the same number of hours of work done but the results might still vary because of the human factor, the tolerances of each engine, defective parts, poorly set timing, injection pumps, etc."
I think you miss the point of using independent testing labs and of having standardized tests that are NOT dependent on having" identical tractors doing the same work" etc. To avoid at ambiguities such as that, standardized tests are developed in all areas of science and engineering. There are innumerable examples. In the case of fuel lubricity, it is the HFRR, but it could, in other engineering fields, be yield tests, fatigue test or fracture toughness tests for metals, pH for liquids, or flow resistance for fluid systems. The point of any test like this is to be able to compare things with identical operating parameters. Does any test tell the whole story. No. But without standardized testing we can't compare anything to anything else. Since, to my knowledge, no fuel supplier will supply us with the lubricity specs of their fuel, we have to go with what we know, which is what the fuel is after removing the sulfur, what the engine and injector manufacturers say is required, and what our EPA requires of fuel suppliers (way higher (worse) than what engine manufactures need. So, bottom line is that some fuel suppliers may have adequate additive packages that provide sufficient lubricity, but we don't know. Our choice entirely. We can have faith that we get adequate fuel, or be proactive using industry accepted tests from an independent lab and and insure we are ok.
/ Lubricity #48
Thanks.:) I'm not saying to or not to try things like biodiesel, for instance, BUT I would caution to look at the potential downside and manufacturer's warnings about use of same.
Careful use of biodiesel, taking into consideration storage life, etc. is one's own personal choice.
/ Lubricity #49
In the real world it would be near impossible to do a study of the effects of each additive on say ten identical tractors, all doing the same work for a set number of hours etc., and then tear their engines down and see quantitative results that would be meaningful to us as to whether to use additives, and which ones, and in what quantity. Ten operators might get the same number of hours of work done but the results might still vary because of the human factor, the tolerances of each engine, defective parts, poorly set timing, injection pumps, etc." End quote.
CM writes:
Sorry, I don't believe I'm missing the point of standardized testing. I am saying that one has to be aware of what and who is looking for what results from any given test. My adult life has been spent working for companies doing 'independent' testing starting with my BA in environmental science, in 1976 when I did testing for Texas Instruments as a subcontractor to Stone & Webster, Boston engineers doing a study of the effects of waste water flow from the Storm King Nuclear plant on the Hudson River.
Followed by working for Mallinkrodt Chemical in the food manufacturing field as a Quality Control lab geek. Then for the DOE on Solar Research and implementation for an MIT engineer and his firm. Since earning an MA in Applied Science, I've done plenty more field and lab work for various companies in similar engineering endeavors, including having own and run various businesses in applied science endeavors.
So back to my point of cautioning anyone ready to buy the snake oil or the we did a test and it proves this particular theory group of believers; caveat emptor- BUYER BEWARE! Just because a particular test says xyz product will grow hair doesn't mean it will. AND beware the money for the testing doesn't come from thin air- somebody with an axe to grind is paying for the test whether one wants to believe it or not.
/ Lubricity #50
From what I have read as long as the bio is entirely plant based, and not used in excess(or switched over from normal diesel to 100% soy) such as a 10% mix there is no downside.
Or have I miss-interpreted something.
If you have info that shows otherwise I am always open for education/discussion.:thumbsup:
/ Lubricity #51
I know just about NOTHING about biodiesel except what little I have read on this forum to date- don't base your decision on anything I've suggested other then carefully weighing the benefits/drawbacks of anything other than off road diesel you might buy locally.
/ Lubricity #52
That is currently what I do.
Purchase offroad diesel(Normal diesel )
and then go to a supplier for a few gallons of soy offroad and mix (10% soy) when I fill my tractor(except winter when its not available)
/ Lubricity #54
From what I see, there isn't sufficient quality control of the biodiesels to absolutely place your faith in the particular batch of fuel you are buying. From one supplier you may ALWAYS get great quality. From another only SOMETIMES. I worry about consistency of formulation as well as age.
So, for me I just use Power Service in commercially available diesel purchased where they sell a lot of diesel fuel. I do qualitatively sense a difference with and without Power Service w.r.t. starting, smoothness of rpms at both low and high, hot and cold. Maybe more power, but I've never pushed the tractor where power was ever in question. So, can't really say.
I only have about 470 hours of history, and replaced my pump at 300 hours. So, it's impossible to really assess longevity. And at my rate of use, I may never get to the thousands of hours needed to state a significant claim. But, at about $12 a year, it does give me peace of mind. And I feel it's less risky than using biodiesel where the quality is not tightly (and independently) controlled.
/ Lubricity #55
Random thoughts:
The lubricity issue is related to wear. From the fuel-pump post-mortem photos on this site, I'd say wear is not the issue but rather failure of the gear materiel or design. Having said that ULSD is a new animal without much of a track record so the jury is still out on long-term effects.
Second bio-diesel quality is indeed an unknown. There should be no problem running on GOOD 100% bio-diesel; but how can you know it's good? On the other hand, a little bio-diesel (maybe 2-5%) probably won't do any harm (even if it's crappy stuff) and it should improve lubrication in the IP and injectors. And that should add life to the machine.
I have owned two Mercedes diesels, I sold a 300TD with 350K miles and I'm still driving a 300SD with 235K miles. Both had the 5-cyl inline engine with inline Bosch IP, not unlike the Kioti configuration. Most of those miles were pre ULSD but it still indicates to me that the basic IP design should be very durable if the right materials are used. With only normal maintenance, these engines should be good for many thousands of hours, not just a few hundred hours. Incidentally, the only fuel additive I used in those cars was a biocide to kill the microbes that grow at the fuel-water interface.
/ Lubricity #56
Where do you go to find this stuff ?
In my area (Topeka, KS) CCO (capital city oil) but I have been told by a friend, whom farms near one thousand acres, that Cenex has quality fuel and he would buy no other brand after using theirs. I have not yet tried theirs. I think they are nation wide company, but I am not sure.
/ Lubricity #57
In our area the Co-op is Country Mark. I believe they are similar to Cenex, not sure though.
Here is Country Mark's
CountryMark - Products - Gasoline, Diesel Fuels, Biodiesel & Lubricants web site.
Here is the link to the page on comparing fuels.
http://www.countrymark.com/sdx4.cfm
/ Lubricity #58
This will get you started - I use Schaeffer's :)
[/IMG]
I use Optilube XPD, its the most expensive (if I remember correctly) but no more than I use, cost is almost meaningless to me in the quantities I burn
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
2015 Scag Turf Tiger 60in Zero Turn Commercial Mower (A64553)
2015 Scag Turf...
2020 John Deere 470G Hydraulic Excavator (A64553)
2020 John Deere...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
