Engine Overhaul
/ Engine Overhaul #1
okietractor
Tulsa, OK
Yanmar 1610 & Century C47L w/50 HL FEL
I am currently working over a Cummins A2300N2 with 363 hours on it. The previous owner ran the tractor, Century C47L w/50 HL FEL, into a pond and sucked water into #2 cylinder which busted the piston and cracked the block. My question is, is it necessary to replace all the main bearings and rod bearings? There was no water damage to anything other than the #2 cylinder. I am ordering a new block as well as piston, rod etc... and don't know if all bearings and bolts have to be replaced if not damaged. I appreciate any help.
/ Engine Overhaul #3
I would replace all main bearings and cap bolts. There were some large shock loads experienced. I don't believe it would be necessary to replace the other rod bearings. What about head damage?
Vernon
/ Engine Overhaul
The head was not damaged. This engine has an abundance of head bolts, the gasket didn't even blow.
/ Engine Overhaul #5
With all that happened.. I can't see NOT replacing the bearings..
soundguy
/ Engine Overhaul #6
Have the rods checked for straightness too. I'd also magnaflux the crank to check for any hair line cracks that may have been generated by the sudden stop at the end.
jb
2005 FORD TAURUS CAR (A66091)
2005 FORD TAURUS...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
ROOM WITH MISC ITEMS (A68842)
ROOM WITH MISC...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2020 GMC SIERRA 1500 (A67714)
2020 GMC SIERRA...
2010 48 ROLL OFF TRAILER (A67714)
2010 48 ROLL OFF...
