engine oil filter change for b2710
/ engine oil filter change for b2710 #1
NewB
Kubota B2710
Need to change oil filter @ 100 hours on 1999 B2710. How to remove left side engine cover for clear access to oil filter? Appears to be attached with some sort of v clips. Use angle needlenose pliers to squeeze clip together & pull up or ??
/ engine oil filter change for b2710 #2
Hi NewB,
Just grab ahold of it with both hands at the top close to the clips and give it a sharp tug towards you/away from the engine. It should pop loose. Mine were kind of sticky so I adjusted the clips and lubed them with lithium grease, now they don't give me any more trouble.
If you can't get it loose with a tug, you can squeeze/spread the clips while you pry with a big screwdriver.
Good Luck
Thanks so much for your reply - Just a little grease, then a tug and the panel came right off - seemed too simple. Had already changed transmission fluid & filter, so now I can complete the 100 Hrs maintenance with the oil filter change.
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
Terramite T9 Backhoe (A65579)
Terramite T9...
2022 EZ-GO ELITE...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
Metal Sunflower Spinner (A65583)
Metal Sunflower...
8ft. x 4ft. Lighted Sign (A65640)
8ft. x 4ft...
