Embarrassing project: getting tractor unstuck
/ Embarrassing project: getting tractor unstuck #61
Glad that you got it out. If it had been mine, it would have drove me nuts until it was out. I think that this is the longest that any one has been stuck on TBN sense the member that had his tractor at the bottom of a hill and couldn't get back out. But, he had some kind of hydro problem, not mud. /forums/images/graemlins/crazy.gif
/ Embarrassing project: getting tractor unstuck #62
Dang!
He beat me to it...
All I got is this little purple one with a BIG RED BUTTON.
</font><font color="blue" class="small">( Glad that you got it out. If it had been mine, it would have drove me nuts until it was out. I think that this is the longest that any one has been stuck on TBN sense the member that had his tractor at the bottom of a hill and couldn't get back out. But, he had some kind of hydro problem, not mud. /forums/images/graemlins/crazy.gif )</font>
Sweet. You know that I was going for the record. I coulda had her out days ago, but I let it carry on just to make for a better story. /forums/images/graemlins/tongue.gif /forums/images/graemlins/smirk.gif
/ Embarrassing project: getting tractor unstuck #64
</font><font color="blue" class="small">( Fear not, Grashopper.* For he who has never stuck his tractor has never tasted the joy of true freedom once it was unstuck.
)</font>
How true, how true, how true /forums/images/graemlins/smile.gif
David
/ Embarrassing project: getting tractor unstuck #65
WOW !!!
Pleased to see you finally got out.
Thanks for the "ahead knowledge" (-:
As I was reading through it I was looking for words like "ground anchor", "Bruce anchor", or "Danforth Anchor".
As a general tactic, has anyone had success with a GOOD boat anchor and winch in situations like this ? I'm thinking 60 or 100 lb muck anchors that dig deeper the harder you pull.
Being out in the flat, with no trees to tie to - tie into the muck itself (-:
/ Embarrassing project: getting tractor unstuck #66
I think physics wouild get you as your anchor has to have at least as much holding power as the thing you are trying to move. That would have to be one _big_ anchor.
Harry K
/ Embarrassing project: getting tractor unstuck #67
I just logged in and was glad too that you got out of that muddy situation...
Now that your out have you given any more thoughts of that TREE you were going after in the first place ??
I'm just curious, I too have been in sticky situations playing around with trees that I was after.....
/ Embarrassing project: getting tractor unstuck #68
Do you have any pictures of the cable setup for the actual pull?
I would really like to see how that was done.
/ Embarrassing project: getting tractor unstuck #69
</font><font color="blue" class="small">( I think physics wouild get you as your anchor has to have at least as much holding power as the thing you are trying to move. That would have to be one _big_ anchor.
Harry K )</font>
Well, maybe not ALL of it - unless the tractor is DEAD and can't contribute anything to the effort at all.
Plows are designed to "cut and skim" and there is a limit to how many of them can be pulled through the ground by any particular tractor. {2, 3, 4, 5 bottom, etc. no surprises there}
Anchors are designed to bury and hold against a horizontal pull, the more you pull the deeper they go. I'd guess 6,000 lb of holding power could be had for ~$100 in something that could be carried out to the rescue site in a gardenway cart - as I said, GUESSING. Anchors are also designed to release easily with a vertical pull, so when you winch yourself to it just pull it up with the 3pt hitch.
Anyway, just a suggestion and I was curious if anyone had tried it. Sailor's call it "Kedging" when they throw out an anchor and winch it in to drag the boat back onto water when it has run aground. So it wasn't an original thought or invention (-:
/ Embarrassing project: getting tractor unstuck #71
<font color="blue">That grapple looks suspiciously like a fish hook, but I like the idea of one of these as an attachment -- good ballast too.</font>
Cliff, I used to fish for the 'BIG' one's..........so I used what I had in stock. /forums/images/graemlins/grin.gif
Don
</font><font color="blue" class="small">( Do you have any pictures of the cable setup for the actual pull?
I would really like to see how that was done. )</font>
It was just two cables attached together and a winch on the front of the guy's F250. The winch slowly pulled and gave the tractor just enough help to make it all the way out of the mud and eventually back onto grass where I hadn't broken through the roots. About 150 feet of cable was needed. A combination of that and the crawfishing was what made it work.
/ Embarrassing project: getting tractor unstuck #73
Cool. I have a field with a wet area, my "wetland". You do realize that the DOE will call that a wetland right? Anyway, there are areas where you just can't tractor in the winter and you have one. Maybe somewhere else on the site is drier.
/ Embarrassing project: getting tractor unstuck #74
Ah, Wetlands!
So ok. I have to build across wetlands to get to my property.
Hire the soil scientists.
Hire out a topographical survey from a surveyor.
Try to get sign off from neighbors, conservation commission, State DES, also copy to Army Corp of Engineers, (Is this Iraq?)
Pay 10 cents a square foot. (plus permit fee.)
wait
wait some more.
Still waiting
Have septic plan held up by findings on unrelated area.
Ok this is to expected.
Here is the best part. Nothing to do with the above.
On the hill side I cleared. Don't forget the "Timber Tax"
Area was never was classified as wetlands. Just forest.
In an area that could be made to collect water, we are going to put in an Agricultural pond. Need a permit, no surprise.
Part of the area classified as low value wetland.
State defines an agricultural pond less than 6 feet deep 'high Value wetland" This is a good thing. right?
So why don't they pay me to build the pond?
No way.
Pay 10 cents a square foot to turn mud into a waterfowl area.
(plus permit fee.)
Now from here to eternity, who forever has complete jurisdiction over the pond?
Not Me! The State DES. They allow no further changes unless I go through process again, etc.
But that's ok. I get to pay Taxes on it so they let me feel like its mine.
Now don't try to cheat, as every year the spy satellite comes over and takes your picture. They do check. State used to use airplanes, but it is cheaper and more accurate to use commercial satellites now with the new resolution they have.
(Last years Military spy satellite!)
I've seen the picture of the two planks out to a canoe they fined the guy $1,000 for doing that without a dock permit.
He got to keep the small dock, so the state is not entirely heartless, just show us the money!
Anyone know where I can get camo nets cheap. Nah, they probably thermal imaging or something else also!.
State Motto "Live Free or Die!"
Ok, this is about getting tractors stuck & unstuck.
Being an expert at getting stuff stuck and still having my Old B7200 and New L39, I've also become an expert at getting them unstuck.
The L 39 BH is strong enough to pick the machine up and move it when necessary. Back Hoes are like Duct tape, +1001 uses. It get real bad though when your digging a hole to get rid of an old (er, I better not say) and you are trying to keep yor machine from falling in the 8' deep hale you just dug. The ground got so mushy the BH bucket buried itself and was stuck from the suction! I lost a lot of timber and planking that day. 3 hours to hose the machine off!
Never did find one of my nice truck ramps with those Heavy duty ramp ends??
/ Embarrassing project: getting tractor unstuck #75
I have learned to do the illegal clearing after the building permit is issued. Do it before and the gov't will catch it in the aerials as part of the permit process and hold up your permit. Do it after and they have no reason to look.
Oh well, I now clear the underbrush and leave large trees behind in an effort to work under the cloak of the trees.
/ Embarrassing project: getting tractor unstuck #76
Danforth style anchors are simple and could be a worthwhile DIY project.
I did a search and came up with this Vhttp://www.danforthanchors.com/deepset.html
the table shows a 75 lb anchor with 6,000 lbs of holding power - claimed. Interestingly, it is only about 4ft by 3ft and fairly flat when folded.
I didn't price it.
Just THINK how deep in you could get with the knowledge that you have something like THIS to help you out (-:
/ Embarrassing project: getting tractor unstuck #77
Reg,
You need to edit your post to take the "V" out of the link to make it work.
/ Embarrassing project: getting tractor unstuck #78
investorguy congrats on getting out of your mire. can't beat good neighbors.
i noticed the discussion of winch anchors above, pull pal makes a most excellent anchor that friends of mine swear by.
http://www.pullpal.com/
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
TIRE RACK WITH TIRES (A67714)
TIRE RACK WITH...
16 Pipe Squeezer (A67714)
16 Pipe Squeezer...
2012 KENWORTH T800 HYDROVAC (A67714)
2012 KENWORTH T800...
213085 (A64276)
213085 (A64276)
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
