Embarrassing project: getting tractor unstuck
/ Embarrassing project: getting tractor unstuck #21
For those of us that have beentheredonethat were feeling for you. /forums/images/graemlins/grin.gif I have some experience in similar situations and had luck using small straw or hay bales. Put them behind the back tires and back up on them. Repeat until you are out. Worked on our IH 915 combine. Although we did have to tunnel under the corn head and remove it because it was under about a foot of mud. /forums/images/graemlins/blush.gif
/ Embarrassing project: getting tractor unstuck #22
I wouldnt worry too much about your neighbors tractor being too small. My neighbor used to be a trucker for an electricity company, moving machinery and cable rolls around the country. when he was stuck on a slippery wet grass roadside, once they pulled him out with a 900 kg Opel Corsa car, that could get some grip on the road with a long enough rope.
One of my earliest memories is when i was about 4, my mother using the Volvo 244 ballasted with a trunk full of feed bags, to pull my father with the JD 510 out of the dump pit when he hung it up on a piece of construction rubble. /forums/images/graemlins/laugh.gif
The trick was to have the rope long enough to get to a spot where you CAN get grip... Mostly it's just all about that few % you needed.
/ Embarrassing project: getting tractor unstuck #24
Crawfishing ou backwards with fel will work well as long as there's something firm enough under the muck to get a bite on with bucket. I just stuck my rig iwith 1500lb cutter n the pond mowing the steep bank. I had to back out with fel for 50ft to a spot where bank was less steep.
/ Embarrassing project: getting tractor unstuck #25
A highlift jack, a bunch of blocking and some tall mud boots would be my suggetion. Use the loader to lift the front end to get some blocks under the front tires and the jack to get some under the rears. My second suggestion would be to get a backhoe to fit that tractor /forums/images/graemlins/smirk.gif. Thats way when the rear end sinks you can use the outriggers from the backhoe to lift the rearend to get some blocks under the tires. Can't count the number of times that I have been in a similar spot. Since I got my Deere with the hoe I have never been stuck to the point where I have had to get help or break out the winch. I am sure the wife will understand the need for the hoe as it will be a money saver in the long run.
/ Embarrassing project: getting tractor unstuck #26
It seems your biggest problem is the lack of ground clearance of the front axle. Lift it up and toss some poles or whatever fill you have, under the front wheels and use your neighbor's little tractor to pull the boxblade away from behind the tractor after you disattached it.
Then pinch the bucket forks into the ground and curl it back untill the oil starts to whistle through the relief valve. then gently drive backwards in a slow gear while keeping full pressure on the bucket movement, and your neighbors little tractor adding some pull with a long rope from a dry spot. Just avoid any wheelspin because when there's no firm subsoil up to axle depth, even spinning mud slicks will cause the earth to move in all directions, bogging you down more.
Once i had my Zetor 5245 on its belly in pig ****... I used a double chain link and had our 2wd 6718 in crawl gear, pull from firm ground. Since i was alone this evening, i had to put the tractor in lowest gear idle and then hop onto the stuck tractor. The helper just started to dig when i put the stuck 5245 in gear, hopped a foot forward and started to bog doen again. I waited a few seconds for the chain to strain, and again drove forward and had it loose... Both tractors were about equal in weight and it was just peanuts. /forums/images/graemlins/ooo.gif
/ Embarrassing project: getting tractor unstuck #27
Here is an old off-roader technique used prior to nylon tow straps, and it works very well. It relies upon the inertial momentum of the towing mass, as opposed to raw traction or horsepower, and it applies zero shock load to either vehicle.
You will need 2 chains, with a total combined lenght capable of reaching from the towing to the towed vehicle, and 1 old used tire. Attach #1 chain to the stuck vehicle and to the tire. Attach #2 chain to the towing vehicle and the tire. The finished setup goes chain-tire-chain.
The chains and tire will look like this:
Towed []----------O-----------[] Towing
Once all is attached, with a driver in both vehicles, the towing vehicle simply drives away accelerating to about 5 -10 mph.
The elasticity of the tire smoothly transfers inertial force to the towed vehicle and out you come. The tire absorbs all of the shock load. Disclaimer: Non-essential people stand clear.
/ Embarrassing project: getting tractor unstuck #28
Investorguy- I sent you a PM. I might be able to help.
/ Embarrassing project: getting tractor unstuck #29
Well...you have enough suggestions. I feel for you. I did the same thing two months ago but was close enough to a tree to winch myself out.
Good luck!
/ Embarrassing project: getting tractor unstuck #30
CurlyDave, anyone ever told you that you look like Kelsey Grammer ("Frasier")?
He isn't nearly as good-looking as I am... /forums/images/graemlins/cool.gif
Okay, I tried the FEL tuck and push routine. I ended up w/ a nice bucket full of clay, but I sure didn't go anywhere. I took a bunch of pics. If you'd like to see them bigger, the gallery is here.
Here're a couple pictures of the tractor in it's current state.
Some pics that illustrate why the bucket move didn't work out too well.
My ruts. I'm so proud...
I tried putting cement blocks (thin) under the back tires to give them something to grab. Didn't work.
This gives you an idea how long swampy it is. That's what the cement block did when I dropped it.
So, I'm at least 100 feet away from anything I could latch onto. Getting a truck out there is problematic at best. I'm not sure I could get the BB off. It's a monster. I could get it off, but I doubt I could move it out of the way. I fear taking a truck out there would just give me one more lawn ornament.
Now that you have a little better idea what I'm up against, any suggestions?
/ Embarrassing project: getting tractor unstuck #32
WOW.
Well, if you don't think you can get the BB off and moved, I think you will need to somehow put some skids under it so it slides. If it catches dirt, it will only hinder the extraction. A 4x8 sheet of plywood, with a 4x4 screwed to the plywood (30-40 screws--10 bolts would be better) and then tip the rear of the plywood up. Not sure how to hold it in place, but it would need to be attached to the BB to hold the rear up.
Then armed with 100+ft of the new steel cable you go buy (not less than 3/8") and all the chain you can muster and a comealong or winch, hooked to your tree, put someone on the tractor to gently apply rear pressure as you winch.
Take a lunch as it will take awhile I think.
Hope some of this helps. Pls let us know how you get out.
Ron
/ Embarrassing project: getting tractor unstuck #33
Ok atleast you tried, but I think you need to move some of that mud out from behind the front right wheel it has no room to move, all the remaining wheels look to be ok. Did you just turn your bucket in the ground or did you really lower it far enough down into the ground to raise the tractor. If not your going to have to raise the tractor front wheels some if you expect to move that tractor.
Regardless of that I'm impressed with the suggestions that were offered. I really thought the one with the 2 chains connected to the tire sounded in theory pretty good, how bout that one.......
/ Embarrassing project: getting tractor unstuck #34
I don't even have my tractor yet and I feel your pain. The only thing I can think of is that country song with the refrain: "Jesus take the wheel".
/ Embarrassing project: getting tractor unstuck #35
Hey Frank29--------- That singers name is Carrie Underwood, last years American Idols Winner and one Fine Country Looking Girl........Thought you should atleast know her name, its a great song...
/ Embarrassing project: getting tractor unstuck #36
I think you really have to get the box blade off the back of your tractor before you get bogged down so far you can't lift it enough to detach it.
Take your pickup down to the local wrecking yard and get a big car hood, maybe even the hood from a pickup truck.
If you turn this upside down, it makes a nice sled. Use some fender washers and eye bolts to give yourself two places to grab it. Despite the fact that you can't horse the BB around manually, you can put the hood under it, drop it on the hood and then pull it out of there.
I was just looking at chain, and 100' of 3/8" proofcoil chain will set you back just under $300, and will be quite useful in the future. Between this, the car/truck hood converted to a sled, and your pickup, you should be able to get the box blade dragged out of the way. Set it up with a short length of chain and a removable link to get a "Y" configuration to pull on both sides of the sled at the same time. You will need an additional 10' or so of chain for this to work properly.
Note: you never have to manually move the BB an inch using this technique, and once you have your tractor free, you can just drive over & pick it up again.
Now put a 4' x 8' piece of plywood under your FEL bucket, hook the chain to the rear of the tractor and slowly pull on it with the pickup while using the bucket to crawfish the tractor backwards. You may have to repeat this a few times to get out.
If this doesn't get you out, and you really want to do this yourself, go out there with a second piece of plywood and a shovel. Dig out enough mud to get the second piece of plywood under the back wheels, so you really have something to grab on to and then try again.
Any way you look at it, you will have some nice ruts to repair in the late spring.
I'll have to look into this chain you speak of. Recomend getting this at Lowes or what?
I do have a 4x8 piece of 3/8 in plywood here. I was planning on using it for a workbench for the paintball shed, but I suppose I can free that up.
The only issue is that it's the back end of the tractor that faces my driveway, but it's at least a hundred feet away.
I may look into that chain/paddle idea w/ the back tires. But I'm not sure I really understand that. Guess I'll be re-reading it.
Calling in the tow truck is something I'm not sure I could handle. I'd rather buy a tool that I can re-use in case I'm ever this stupid again.
That's it, I'll tell my wife it's stupidity insurance. She may actually buy that...
/ Embarrassing project: getting tractor unstuck #38
I refer to another thread on this site,"neighbnors and what to do with them". At this point i good neighbor might be the right thing.
You are really not that stock, yet. It is just too slippery to get out. Find someone in the neighborhood , or gather all the neighbors, each bringing the chains and ropes they have, connect to a tractor on dry land, and you will be out in no time! Stop trying to get out by yourself, each attemt makes you go deeper into the mud.
This is also a good way to meet the neighbors, you need them, they get an opportunity to show you how helpful they really are, a common project makes talking informal and easy. You, of corse, will be the laughing stock of the naighborhood! Is this project just a clever way to meet the neighbors, judging from the tracks leading to where you are stuck now, it must be!
Good idea. I do have a fridge full of Corona...
/ Embarrassing project: getting tractor unstuck #40
Plant some flowers in the bucket! /forums/images/graemlins/tongue.gif
Cable, snatch block and a come along.
To lift the front end place several 4x4x8 lengthways under the bucket.
If possible find some spruce or pine branches to place under the wheels for support.
Do not even consider using the truck! /forums/images/graemlins/tongue.gif
It's frustrating being stuck. All the advice can be even more frustrating.
Time and patience will do wonders.
Egon /forums/images/graemlins/grin.gif
