Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,084
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We're building a small addition on to the house.
When we finished the outside garden several years ago, the wife wanted some lights along a path. I buried two 12-2 uf wires (ditch witch) and have her lights up & wired.
The ENDS of the wire were NOT yet brought into the house yet. They ran from the path to my patio and into conduit under the patio. The conduit was really only about 12" deep, under 3 inches of "sand" and then under my flagstone rocks that float on the sand.
Today, we're adding onto this area and I showed the contractor the two wires that were simply jutting out of the ground.
I dug them up, pulled them back so they could dig their foundation for the room.
When they poured the concrete foundation, they put the conduit back into the (shallow) ditch I'd previously had BUT... they did NOT add any conduit to it to bring the wires 'up' inside conduit.
The wires are buried partially in concrete. You can see them in the picture, coming out of nowhere.
What's worse (possibly), the foundation is say, 24" wide and we're using 8" blocks so the wire now comes out into the room away from the wall instead of inside or at the wall.
I asked him about this and he said it wasn't a problem... they'd simply bend the wire towards the wall (which would be on the left side of the picture) and pour the concrete floor, effectively burying the wire in yet another layer of concrete.
I can't say I've ever seen this done and am wondering if this is acceptable in any fashion or, if I need to perhaps get the electrical inspector out to 'notice' this and have them fix it?
I'm rather preturbed at how they did this since $5.00- worth of conduit would have given us a complete path to pull the wire through if ever needed in the future. If however, it IS acceptable, I don't think I can complain too much.
Thoughts??
PS: I'll point out for better or worse, the reason this last section under the patio is so shallow is this is also where the main house power line comes in and I didn't want to be ditch witching around that and make a mistake. We've got buried rocks here (boulders at times) and when they layed the electrical wire to my transformer box, I know for a fact they were not always a consistent depth. I didn't want to 'trust them' at my patio which is also why I had it in conduit.
Thoughts??
