electric snow blower shoot
/ electric snow blower shoot #1
NBstunter
new brunswick canada
2006 kubota L2800
how do i make one? i looked around and found the one with the winch motor but im ADD and cant wait a year for it to move side to side i have tryed 2 different things a window piper motor with a 14 tooth sprocket and a chain running to a 14 tooth sprocket to turn it it took 32 seconds to go from one side to the other, way to slow i had an old starter off a ATV tryed it with a 12 tooth on it and a 43 tooth on the thing to turn the shoot it goes from 1 side to the other in 1.4 seconds flat and its violent so not gonna work. and how do i wire it? like i cant put power to the hole ground of the tractor and ground the 1 wire off the motor im at a loss and the cabs going on the tractor and a crank isnt gonna work.. and it doesnt have hydro take off for anything but the bucket and i dont feel like blowing $300 to get that working. i have a welder and am open to any ideas thanks in advance
/ electric snow blower shoot #2
Go to the main page, Then General Forums, then Build-It Yourself, then in the upper right, look for the Search boxes, In "Search this Forum, type "Chute" no quote marks! You'll find a lot of reading, if you opt for the more conventional spelling of Chute ! And 'Hey' welcolm to TBN! ~Scotty
/ electric snow blower shoot #3
Before you go too far.....make sure your engine can power a battery. Many snowblowers have only an A/C circuit to run a little light.
/ electric snow blower shoot #5
/ electric snow blower shoot #6
I have a similar set up on my blower with a window motor and a cable wrap around the chute. It has worked remarkably well after 3 years, the only issue I had originally was that it was slow until the area between the chute and the collar it rotated against got wet, then it was fine. I changed the small metal shoes the chute rotated against with small bearing like a cam follower no more issues. I also added a electric linear actuator for the chute damper and a larger one I had as a top link. With the adjustable top link I can float over my gravel driveway but cut through the ice on neighbors paved drives.
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
JMR 4ft Tree Boom Skid Steer Attachment (A64553)
JMR 4ft Tree Boom...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2024 CATERPILLAR 304 EXCAVATOR (A65053)
2024 CATERPILLAR...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
