Electric Problem ford 8n
/ Electric Problem ford 8n #1
lostinspace
wa
ford 5000
I purchase a Ford 8N some time ago. I removed the 6v battery without noticing the way the battery was hooked up. Do you hook the red cable that comes from the stater/solenoid to the positive post on the battery or hook it the neg post. I have forgotten most of what little knowledge I had about this stuff. If someone respond's to this please detail the information.
THANKS IN ADVANCE.
/ Electric Problem ford 8n #2
THANKS IN ADVANCE.
The old 6 volt 8N Fords were Positive Ground.
/ Electric Problem ford 8n #3
THANKS IN ADVANCE.
If it has the original generator/regulator/6V battery then it is a positive ground system. If it's converted to an alternator and is 12V it is a negative ground system.
/ Electric Problem ford 8n #4
The n's all left the factory 6 volt, positive ground and are best left that way. Hook the red (ground) cable to the positive post of your 6 volt battery. If the tractor starts good with the factory 6 volt system, you know the engine is in pretty good shape and has good compression. 12 volt conversions were often done to help worn engines start easier and are a "red-flag" to most collectors.
/ Electric Problem ford 8n #5
12V conversions were also done because trying to keep the six volt battery charged with a generator could be a real pain in the rear, especially in the middle of winter!
Does the red cable come off the solenoid.
/ Electric Problem ford 8n #7
THANKS IN ADVANCE.
The battery posts are different diameter, positive is slightly larger. Match the cables to the size of the posts.
/ Electric Problem ford 8n #8
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
1991 Ford F600 Fuel Truck, VIN # 1FDNK64P0MVA37029 (A65563)
1991 Ford F600...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
Westfield Gravity Wagon Auger (A66408)
Westfield Gravity...
