Electric Problem ford 8n
/ Electric Problem ford 8n #1
lostinspace
wa
ford 5000
I purchase a Ford 8N some time ago. I removed the 6v battery without noticing the way the battery was hooked up. Do you hook the red cable that comes from the stater/solenoid to the positive post on the battery or hook it the neg post. I have forgotten most of what little knowledge I had about this stuff. If someone respond's to this please detail the information.
THANKS IN ADVANCE.
/ Electric Problem ford 8n #2
THANKS IN ADVANCE.
The old 6 volt 8N Fords were Positive Ground.
/ Electric Problem ford 8n #3
THANKS IN ADVANCE.
If it has the original generator/regulator/6V battery then it is a positive ground system. If it's converted to an alternator and is 12V it is a negative ground system.
/ Electric Problem ford 8n #4
The n's all left the factory 6 volt, positive ground and are best left that way. Hook the red (ground) cable to the positive post of your 6 volt battery. If the tractor starts good with the factory 6 volt system, you know the engine is in pretty good shape and has good compression. 12 volt conversions were often done to help worn engines start easier and are a "red-flag" to most collectors.
/ Electric Problem ford 8n #5
12V conversions were also done because trying to keep the six volt battery charged with a generator could be a real pain in the rear, especially in the middle of winter!
Does the red cable come off the solenoid.
/ Electric Problem ford 8n #7
THANKS IN ADVANCE.
The battery posts are different diameter, positive is slightly larger. Match the cables to the size of the posts.
/ Electric Problem ford 8n #8
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59912)
2009 STRICK 53X102...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
