Electric Problem ford 8n
/ Electric Problem ford 8n #1
lostinspace
wa
ford 5000
I purchase a Ford 8N some time ago. I removed the 6v battery without noticing the way the battery was hooked up. Do you hook the red cable that comes from the stater/solenoid to the positive post on the battery or hook it the neg post. I have forgotten most of what little knowledge I had about this stuff. If someone respond's to this please detail the information.
THANKS IN ADVANCE.
/ Electric Problem ford 8n #2
THANKS IN ADVANCE.
The old 6 volt 8N Fords were Positive Ground.
/ Electric Problem ford 8n #3
THANKS IN ADVANCE.
If it has the original generator/regulator/6V battery then it is a positive ground system. If it's converted to an alternator and is 12V it is a negative ground system.
/ Electric Problem ford 8n #4
The n's all left the factory 6 volt, positive ground and are best left that way. Hook the red (ground) cable to the positive post of your 6 volt battery. If the tractor starts good with the factory 6 volt system, you know the engine is in pretty good shape and has good compression. 12 volt conversions were often done to help worn engines start easier and are a "red-flag" to most collectors.
/ Electric Problem ford 8n #5
12V conversions were also done because trying to keep the six volt battery charged with a generator could be a real pain in the rear, especially in the middle of winter!
Does the red cable come off the solenoid.
/ Electric Problem ford 8n #7
THANKS IN ADVANCE.
The battery posts are different diameter, positive is slightly larger. Match the cables to the size of the posts.
/ Electric Problem ford 8n #8
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2016 Ford Fusion Titanium Sedan (A61574)
2016 Ford Fusion...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
