Electric Fence - not working.
   / Electric Fence - not working. #21
Do you have the wire connected together in a complete circular path? An electric fence uses the earth to complete the cicuit.
   / Electric Fence - not working. #22
Thread over 13 years ago . By now the rancher, farmer etc might have other things "not working" . :)
   / Electric Fence - not working. #23
Gentlemen,
Please enlighten me to where I went wrong. I purchased a (110v) electric fence-charger from TSC. Rated for 5-miles of fence - my little pasture is less than 1/2 mile around. Aluminum wire, insulators on all wood posts, Ground-rod is 6' galvanized with clamp to ground wire (not just looped to it tightly). Nothing is touching (grounding out) the wire. The box is close to a powerpole, but not THAT close. I'm using 10ga wire from the charger to the fence. I understand its rated for only 600v, but I should get SOMETHING to the fence wire. I get nothing. what am I doing wrong?
Please help be before this percheron/thoroughbred cross tears up the fence.
Thanks,
49T&C
Can you provide a little more info on your circuit? Or simply disconnect from the fence (keep the ground in the ground) and test for function at the out put terminal.
   / Electric Fence - not working. #24
Rgladden welcome to the forum . :tractor:
   / Electric Fence - not working. #25
Using 600V rated wiring is not good enough... The electricity from the charger is leaking to atmosphere... Humidity does that.... Go buy the wiring rated for a fencer.... Your fencer emits probably 50,000 volts and that will jump to anywhere it can.....
I tried household 12ga. wire .... no go.... changed to the high voltage charger wire and all was fine......
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
John Deere TX Gator (A60462)
John Deere TX...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
