Electric Brakes
/ Electric Brakes #51
THAT is a very good point - and a move that needs to be PRACTICED !
Whenever I hook up a trailer I check the manual override on the controller (called the "trolley brake" in various CDL literature and license exams).
I check again as I start to move at about walking pace - yes the trailer brakes ALONE do slow the truck and trailer so everything is connected and working - this check also reminds my subconscious where the manual override is.
I have only had to use it a couple of times to get me out of trailer sway, but was SO thankful that the reflex was there.
{I hate to have to admit it, especially HERE, but loading the tractor too far back has been the cause of insufficient tongue load that has lead to sway}
Once in a while I go through a test of the breakaway system, it goes about like this;
1) Get the rig on grass or dirt,
2) pull the trailer plug to simulate the trailer detaching from the truck
3) pull the breakaway pin on the trailer
4) drive forward a couple of feet and check that all trailer wheels have skidded, i.e. all trailer brakes were locked.
5) leave it like that for 10 or 15 minutes to check that the trailer's breakaway battery can hold enough charge to keep those brakes ON (legal requirement is 15 minutes).
6) pull forward again to see that the trailer drags its wheels.
7) Put the breakaway pin back in, reconnect 7 pin trailer plug, finish a normal circle check, etc., get on my way.
CHEAP ain't the way to go with trailers and trailer brakes, we have but one life, etc. and even ONE un-braked thousand pounds wiggling around on a little ball behind me is too much.
EVERY time I hitch up or change my load I check the calibration on my brake controller. Get a little speed going (10-30mph) & hit the actuator on the brake controller. If the trailer brakes dont aggressively slow the whole rig without locking up, adjust it up or down as needed.
It builds muscle memory for where the lever is & makes sure everything actually works. In addition to making sure its calibrated properly. I do it with my 3,500lbs travel trailer as well as my 14k deckover loaded or not.
/ Electric Brakes #52
Agreed, a little bit of accelerator and a little bit of trailer brake application at the same time will "pull things straight" while slowing below the speed of sway onset - and YES it does have to be a conditioned reflex (burned into muscle memory).
My routine seems to have put it there BEFORE getting into a catastrophic sway, even little sways can bring belief - pun alert; to borrow a phrase "scared straight".
/ Electric Brakes
thanks for all the info guys. I bought the trailer with the electric brakes, I don't think I will ever go to surge brakes again.
2009 Ford F-150 Crew Cab Pickup Truck (A59230)
2009 Ford F-150...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2019 Ford Transit 250 Cargo Van (A59230)
2019 Ford Transit...
iDrive TDS-2010H...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2012 MACK GRANITE-GU713 (INOPERABLE) (A60736)
2012 MACK...
